Supreme Cutlass Posted November 12, 2007 Report Posted November 12, 2007 Is that a bit high, and how high is too high? that's at freeway speeds, it falls down to about half at idle Quote
Psych0matt Posted November 12, 2007 Report Posted November 12, 2007 mine is always pegged I also have the wrong sensor in it, which I've been meaning to switch... Quote
Brian P Posted November 12, 2007 Report Posted November 12, 2007 engine's still under operating temp. For that gauge that is normal. Quote
Nick1234 Posted November 12, 2007 Report Posted November 12, 2007 colder weather affects it as well. Quote
rockfangd Posted November 12, 2007 Report Posted November 12, 2007 lol the only time mine gets that good is when i am at almost wot . usually it runs around half Quote
Andrew Posted November 12, 2007 Report Posted November 12, 2007 engine's still under operating temp. exactly. colder oil = thicker oil = higher oil pressure. besides, we all know how accurate our gauges are. Quote
Supreme Cutlass Posted November 13, 2007 Author Report Posted November 13, 2007 well, it's 80 degrees down here and the sender is new... Quote
Grand Moff Joseph Posted November 13, 2007 Report Posted November 13, 2007 When cold, my 3.1 has the oil pressure pegged, cold weather or not. Once it heats up, the pressure drops to between zero and the first hash mark on idle. Quote
1990lumina Posted November 13, 2007 Report Posted November 13, 2007 When cold, my 3.1 has the oil pressure pegged, cold weather or not. Once it heats up, the pressure drops to between zero and the first hash mark on idle. Same. Quote
digitaloutsider Posted November 13, 2007 Report Posted November 13, 2007 Don't worry about it being pegged, worry about it being on the opposite end of the gauge. Quote
19GT92 Posted November 16, 2007 Report Posted November 16, 2007 mine runs between 40 and pegged at operation temp so its all good but i use mobil one oil Quote
RangeStang Posted November 16, 2007 Report Posted November 16, 2007 The oil senders in these cars suck If you are really that worried about it go aftermarket. Quote
