alphagtp Posted November 11, 2007 Report Posted November 11, 2007 So I have a 94 GTP, wich kinda of car has the factory FSTB that would fit mine? I was at the junk yard and I only saw the bonneville, eighty eights, and some other buick has them but I don't think they would fit, but I'm not sure... Quote
Euro Posted November 11, 2007 Report Posted November 11, 2007 the only factory STB that will work for 1st Gen's is the one off of a 91-95 Cutlass convertible. Quote
alphagtp Posted November 11, 2007 Author Report Posted November 11, 2007 Do they all of them have them or is it an option?? Quote
Addicted To Boost Posted November 11, 2007 Report Posted November 11, 2007 All Cutlass convertables have them. Quote
alphagtp Posted November 11, 2007 Author Report Posted November 11, 2007 Good !! now I just need to find one... Thanks Quote
xtremerevolution Posted November 11, 2007 Report Posted November 11, 2007 Good !! now I just need to find one... Thanks LOL!!! Quote
CSI_MuNkY Posted November 11, 2007 Report Posted November 11, 2007 The Buick F-bar will work too, I have it on my 95 GTP, It cleared the motor just fine, it rubbed on the underside of the hood but I put a small (1/4") dent in the bar where it hits the hood, no more rubbing. All I did was drill 2 holes into the stock strut tower plates and bolt it to them using bolts with a low profile head. It bends the plate a hair, but its no big deal. If you got really picky you could drill the holes straight through the tower and put the bolts in from underneith. This is probably what I will do next summer, I think if I had done that in the first place there woudl of been no need for the dent in the bar. Jamie Quote
ManicMechanic Posted November 11, 2007 Report Posted November 11, 2007 If you have a GTP with the DOHC (as if there's any other kind, lol) you will need to find a 1993-95 convertible. 3.1, 3100 or 3.4. An STB from a 1990-92 3.1 car WILL NOT fit a 3.4 car Quote
ManicMechanic Posted November 11, 2007 Report Posted November 11, 2007 I have a 3.4 bar that i could be persuaded to part with...If you don't mind it having been bent somehow - the car I got it from had not been wrecked. It fits fine though. Quote
Chancho Posted November 12, 2007 Report Posted November 12, 2007 how much do you want for it, bend and all Quote
Euro Posted November 12, 2007 Report Posted November 12, 2007 I have 2 3.4 bars I should throw up FS on here. Quote
pontiacmaniac94 Posted November 14, 2007 Report Posted November 14, 2007 dude, just make one..... i got my front strut bar outta of 94 buick lebsabre, i redrilled the holes on the bracket, and reused the square stock, all you had to do was loosen the square stock to fit longer, and you are all set. just go to like I-435 and 12th(truman road) and pick one up from U-pick and pull Quote
Psych0matt Posted November 14, 2007 Report Posted November 14, 2007 hmmm, not a bad idea, and easier to come by... Quote
Bossman429 Posted November 14, 2007 Report Posted November 14, 2007 dude, just make one..... i got my front strut bar outta of 94 buick lebsabre, i redrilled the holes on the bracket, and reused the square stock, all you had to do was loosen the square stock to fit longer, and you are all set. just go to like I-435 and 12th(truman road) and pick one up from U-pick and pull Too late, I already got 'em all! Actually when I go junkyarding I hit up the Pick N Pull, and the U Pick it and usually find a vert in one of the 2. There was a vert in the U Pick it last time I went (month ago) Quote
GutlessSupreme Posted November 14, 2007 Report Posted November 14, 2007 That lesabre bar is BEEF. Quote
Chancho Posted November 14, 2007 Report Posted November 14, 2007 How does that bar hold up after it gets re drilled up by the square bar and down at the brackets Quote
Euro Posted November 14, 2007 Report Posted November 14, 2007 How does that bar hold up after it gets re drilled up by the square bar and down at the brackets It doesn't look like an extra 2 holes would weaken it at all. They're pretty strong. That is a good idea, last time I was at the yard I counted probably 8 cars with that STB. Quote
Chancho Posted November 14, 2007 Report Posted November 14, 2007 yea those stb's are all over the place here in orlando, now a vert... good luck on finding that, a vert stb is my ultimate goal Quote
intern8tion9l Posted November 14, 2007 Report Posted November 14, 2007 buick far FTW. although that lesabre one looks pretty good too. cutty vert bar FTL Quote
ManicMechanic Posted November 14, 2007 Report Posted November 14, 2007 how much do you want for it, bend and all Let me get things organized and go from there...Plus I need to get it off my car and put on the 3.1 bar. Quote
3.1cutlass Posted November 14, 2007 Report Posted November 14, 2007 buick far FTW. although that lesabre one looks pretty good too. cutty vert bar FTL I have one on my cutlass too. Quote
alphagtp Posted November 14, 2007 Author Report Posted November 14, 2007 I dont know if those bars will clear my 3.4, it seems like it wont!! and Im to lazy to drill holes and all of that, lol. Im going to give it a try to find a 3.1 cutty bar, if I dont find one in a month or so, I'll go for the buick one, the junkyard I went to had a lot of them Quote
ManicMechanic Posted November 14, 2007 Report Posted November 14, 2007 A 3.1 bar will not work in a 3.4 car...You will need a 3.4 bar. Quote
alphagtp Posted November 14, 2007 Author Report Posted November 14, 2007 If you have a GTP with the DOHC (as if there's any other kind, lol) you will need to find a 1993-95 convertible. 3.1, 3100 or 3.4. An STB from a 1990-92 3.1 car WILL NOT fit a 3.4 car Are you correcting yourself ?? :confused:So i need to find A convertible 93-95 with a 3.4?? Quote
