ns87 Posted November 6, 2007 Report Posted November 6, 2007 I feel when I work on my car, more shit breaks than I fix. Anyway! My car has the most bone jarring 2-1 downshift..... and the downshift is not at the same speed it used to be (used to be around 18mph, now its about 12mph). Last year I replaced the vacuum modulator. I'm going to replace the vac line going to it (could this be caused by a vacuum leak). Also, I want to adjust the TV dentent cable, but I can't depress that button AT ALL. As much as I force it, it will not depress. Any ideas? Thanks guys, you're usually really helpful Quote
ns87 Posted November 7, 2007 Author Report Posted November 7, 2007 Bump. So, I was wrong its the 3-2 downshift. That little elbow rubber line to the modulator is indeed cracked, and I will replace it. But with it not connected, fluid came out the modulator with the car running. Is this signs of a bad one, or is it bc there is no vacuum pressure? Quote
Addicted To Boost Posted November 7, 2007 Report Posted November 7, 2007 When fluid is coming out your modulator, your modulator valve is bad. Quote
ns87 Posted November 7, 2007 Author Report Posted November 7, 2007 When fluid is coming out your modulator, your modulator valve is bad. But theres none in the tube, this is when the tube is disconnected Quote
mfewtrail Posted November 7, 2007 Report Posted November 7, 2007 Fluid coming out = it's bad. If it's coming out with the tube disconnected, it's going to be sucked into the intake manifold when the tube is connected. As for the detent cable, use a large screwdriver to depress the button. If you still can't get it, have someone else adjust the cable for you while you use both hands to push down w/ the screwdriver and depress the button. They're usually pretty tough to mash down... Quote
ns87 Posted November 7, 2007 Author Report Posted November 7, 2007 Fluid coming out = it's bad. If it's coming out with the tube disconnected, it's going to be sucked into the intake manifold when the tube is connected. As for the detent cable, use a large screwdriver to depress the button. If you still can't get it, have someone else adjust the cable for you while you use both hands to push down w/ the screwdriver and depress the button. They're usually pretty tough to mash down... Thanks mfewtrail and nick. Thats so funny, I installed this modulator a year ago and hated how it wasn't adjustable. Oh well, I guess now I have an excuse to get an adjustable one. Quote
ns87 Posted November 9, 2007 Author Report Posted November 9, 2007 Where do I find an adjustable one. Advanced auto and autozone both don't have an adjustable one Quote
pwmin Posted November 9, 2007 Report Posted November 9, 2007 Pioneer 747017 supposedly, o'riley's has them, but i dont have one around here, so i wouldnt know. http://www.60degreev6.com/showthread.php?t=37641 Quote
ns87 Posted November 9, 2007 Author Report Posted November 9, 2007 cool. I dont either have one either, but I just bought it online. They expect it to be here in a week The shipping cost almost as much as the part, but its worth it to me. Quote
ns87 Posted November 16, 2007 Author Report Posted November 16, 2007 its amazing. I can not believe my car shifts that well. Like I've read, turn it 2 cranks and its perfect! I did 3 and it was too harsh, two is perfect Quote
RangeStang Posted November 16, 2007 Report Posted November 16, 2007 That is the same exact thing my lumina does. I adjusted the TV dentent cable it helped a little but not much I bet that is what is wrong with mine. Thanks Quote
ns87 Posted November 16, 2007 Author Report Posted November 16, 2007 no prb. its a world of difference I swear. Just take off the air box and its right below. Took less than 5 min. Try to get the adjustable one though. My first replacement wasn't, and this adjustable one is 100X better! Quote
RangeStang Posted November 16, 2007 Report Posted November 16, 2007 If you don't mind me asking how much did you pay for the adjustable one? Quote
pwmin Posted November 16, 2007 Report Posted November 16, 2007 i wish i knew about these when i had my 96 Quote
