limp mode
hell_raiser
Its what happens when your not around a hot chick thats nekkid :lol:
Sry... had to :lol: :leaving:
what is it? do you have reverse in it?
yes.
but I told you what it was in the OTHER THREAD on this topic.
p.s. this applies to the Electronic transmission only.
when the transmission falls into failsafe mode, the trans is in 3rd gear in OD and D, and 2nd gear in 2 and 1.
Here is what I think is happening. your PCM is not receiving enough power to operate properly, so it has defaulted to operating the transmission in failsafe mode. you should not change gears and accelerate while the vehicle is traveling in the opposite direction. the fact that you did so while your car was in failsafe.... instead of going into 1st, you went right into 3rd... and stalled. Hence....your car was broken before the shift and stall incident.
check wires, check alt and battery!
and furthermore... there is no shifting what so ever, unless you manually shift between OD or D into 2 or 1
also, the E tranny will stay in 1st gear at all times in the event of a Vehicle Speed Sensor failure.
LMAO :lol:
ahhahahhahahha well i have no back-up gear soo i guess i will get out and push then eh lol
My Z34 went into limpmode due to a short in the VSS harness.
Sounds like a personal problem Id recommend Viagra or Cialus
well he would know....... he has used both!
He has to, otherwise Slick has to be in the bedroom as well. :lol:
:lol:
lmao it fixed its self ah lol, i was driving then i down shifted to 2 like i always did than the trans gave out then came back i noticed reverse working so i put on the tcc plug and boom i have 1 2 3 d and r.
weird ah
