greencutlassdrvr Posted November 3, 2007 Report Posted November 3, 2007 i bought some xlaces... the back fit perfect but does any one know why i need spacers up front? i thought the offsets were the same... i have a 97 cutlass Quote
Addicted to eaton Posted November 3, 2007 Report Posted November 3, 2007 Brake rubbing is my guess Quote
White93z34 Posted November 3, 2007 Report Posted November 3, 2007 spacers up front??? when i ran them they tended to rub the one side of my wheel well a little bit but i ran them for a long time like that, spacers would make them look flat out silly. Quote
GutlessSupreme Posted November 3, 2007 Report Posted November 3, 2007 x2^ you don't need spacers, and it would look retarded with them. People have had different results, some say no rub, others say some rub but only at full lock. don't worry about that. you definitely shouldn't need spacers. Quote
greencutlassdrvr Posted November 4, 2007 Author Report Posted November 4, 2007 thats what i thought but the inside of the wheel is rubbin up against the caliper bracket Quote
ManicMechanic Posted November 4, 2007 Report Posted November 4, 2007 Did you get 1st gen GP X-laces, 2nd gen X-laces or Bonneville X-laces? Quote
greencutlassdrvr Posted November 4, 2007 Author Report Posted November 4, 2007 i ordered them at work for an 89 tgp do u think thats what it is? Quote
ManicMechanic Posted November 4, 2007 Report Posted November 4, 2007 They should be 16x8 1st gen GP then. There shouldn't be a reason for them to rub. I believe there's someone here with a 1996 or 1997 CS with GP X-laces, hopefully he will come up with something. Quote
greencutlassdrvr Posted November 4, 2007 Author Report Posted November 4, 2007 yea i member seeing his sig pic on here and the car is the exactly like mine and i got the bronze ones... to i cloned his car hopefully he doesnt hate haha Quote
GutlessSupreme Posted November 4, 2007 Report Posted November 4, 2007 I have the newer brakes on all 4 corners of my STE and there are no clearance problems to speak of. I don't think Bonneville crosslaces fit (different bolt pattern?) and the 2nd gen crosslaces I think are only those nasty wavy ones, not the straight ones like I have. they are 16x8" right? Quote
ManicMechanic Posted November 5, 2007 Report Posted November 5, 2007 Bonnies have the same BP as Ws. But different backspacing and width, as I recall. Quote
GP1138 Posted November 5, 2007 Report Posted November 5, 2007 Bonnies have the same BP as Ws. But different backspacing and width, as I recall. Ken said this too. I saw a perfect set of crosslace wheels on a Bonne in a yard, but they didn't look like the W-Body xlaces. Quote
Pontiac6KSTEAWD Posted November 5, 2007 Report Posted November 5, 2007 Bonnie cross laces will bolt up, but well drag and grind on the calipers something mad. Drive it with them like that for about 20 miles, no more rubbing. I found this out the hard way, I bought a pair of them, thinking they were the TGP style, and then let the wife drive it home. We get home and she tells me about this horrid noise coming from the back end, but it went away half way home.. Luckily the rim metal is alot softer than the caliper metal. Quote
greencutlassdrvr Posted November 5, 2007 Author Report Posted November 5, 2007 Bonnie cross laces will bolt up, but well drag and grind on the calipers something mad. Drive it with them like that for about 20 miles, no more rubbing. I found this out the hard way, I bought a pair of them, thinking they were the TGP style, and then let the wife drive it home. We get home and she tells me about this horrid noise coming from the back end, but it went away half way home.. Luckily the rim metal is alot softer than the caliper metal. the back end is fine... but its just the front they are the 16x8s so i have no idea what the prob is... i know theyre not the bonnies cause i compared them to my friends today so i dk Quote
greencutlassdrvr Posted November 8, 2007 Author Report Posted November 8, 2007 yea i know.. at first i thought it was because i had the baer deccelarotors on there but.. i put the stock rotors back on there and still rubbed and needed the spacers... this is the only one i got right now.. ill take some later Quote
