Cruise Control Requirments
I have a 95 GP GTP. The cruise has not worked since I have owned the car. What is required for the cruise to work? I have replaced the Cruise Control Module and the stalk inside the car. Is there something else that controls it?
Fuse. lol
Fuse. lol
Fuse is good. Have checked it already. Just forget to mention it in the first post.
i have had some problems with bad hoses not sealing all the way, might be somthing to look at.
I think you have the older style. Which runs off of vacuum. Mine is electronic.
Does the HVAC system work properly? does it shift between floor, vent and defrost properly?
HVAC works fine. Defrost does work, but not as fast as it should. The A/C isn't charged up so yea.
Brake Light Switch? That could be keeping it from engaging. Also, maybe check to make sure that there are no broken wires in the signal stalk.
