Where is the coolant temperature sensor located?
I just bought a 1989 Turbo Grand Prix, I was wondering where the coolant temperature sensor is located? thanks
Congrats on the TGP :smile:
Temp sensor for the gauge. Rear head just below the valve cover on drivers side one wire.
Temp sensor for ECM, under TB in V of LIM towards front. three wires.
Jud
Jud
Hey Jud, thanks, it is the temp sensor for the ECM I am looking for (I should have been more specific), is TB the turbo? and sorry not sure what LIM is?
Thought I might change it, I have changed almost all of the other sensors..thanks
Ahh..
TB = Throttle Body
LIM = Lower Intake Manifold
I think I found it but is it possible it has 2 wires to it a green and a black with red stripe? Its actually quite accessable.
Yea could be two wires. It's only been a few year since I've seen mine.
Why are you going to change it? If the fans work properly it's ok.
Jud
I am trying to restore the vehicle as much as possible, I have changed most of the sensors (MAP, TPS, O2, EGR valve and the ECM which was bad, I havn't priced it yet but I will today.
yup it has two wires, pretty easy to change
