282 from quad 4 work on 3.4x?
I found a local cutlass that runs great. Its a got a quad 4 282 setup. Will it bolt up to my 3.4x v6?
Also the gearing will be really different than a 2.8/31. 282 and most likely a 284
The majority of the gears are the same but really thats all that can be of any good to you, the bellhousing is diffrent so you need a getrag 3x00 v6 or 2.2 trans to swap the guts into as long as its a getrag trans your safe to swap internals, but really if you find a complete tranny that will bolt up you might as well use it, forget about the olds, unless you find a broken v6 tranny cheap but still... not worth it.
