stryker Posted October 21, 2007 Report Share Posted October 21, 2007 3 months ago I replaced the water pump on the 3.1v6 and I still can't get the low coolant light to go off. I have checked the coolant every weekend for the last couple of weeks just to make sure the light isn't on for a 'real' reason. But it is always full,in the rad. and it's where it's supposed to be in the recovery tank. I even tried resetting the computer but it's still on. Anyone have any ideas or advice? I would like to get this fixed cause i'm trying to sell the car. Thanks,Lee. Quote Link to comment Share on other sites More sharing options...
BXX Posted October 21, 2007 Report Share Posted October 21, 2007 Did you properly bleed the air outta the coolant system?? Quote Link to comment Share on other sites More sharing options...
runt Posted October 21, 2007 Report Share Posted October 21, 2007 Bad sensor? Quote Link to comment Share on other sites More sharing options...
joey b Posted October 21, 2007 Report Share Posted October 21, 2007 more than likely a dirty sensor. They get gunked up and don't read correctly. It is located on the passenger side of the radiator. Take it off the radiator and scrape the crap out. Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted October 21, 2007 Report Share Posted October 21, 2007 What Joey said, or replace the sensor. But they arent cheap. 68 bucks at autozone. Quote Link to comment Share on other sites More sharing options...
stryker Posted October 21, 2007 Author Report Share Posted October 21, 2007 I was thinking that I had bleed the system but I will try and do it again to see if it helps. Thanks,Lee. Quote Link to comment Share on other sites More sharing options...
