DRGrocho Posted October 19, 2007 Report Posted October 19, 2007 I don't have a Chilton or Haynes manual for the 1991 Regal GS that I just bought, so can somebody just post up the procedure for changing a front wheel bearing? I'm trying to decide whether or not to do it tomorrow after I change the oil on the Lumina again. Quote
5speedz34 Posted October 19, 2007 Report Posted October 19, 2007 Basically remove the brakes. The big CV Nut 35mm or 36mm? Unbolt the 3-4 bolts behind the strut tower and disconnect abs lines if equipped, and it should come right out! Quote
Bri-Guy-GA Posted October 19, 2007 Report Posted October 19, 2007 on my 95 GP they were 36mm. You also need a gear puller or something to push the axles out of the bearing unit. Loosen the bolt with somebody holding the brakes if you don't have an impact gun. Make sure you replace the axle nut with new ones. The manual says to never re-use these nuts. Quote
DRGrocho Posted October 19, 2007 Author Report Posted October 19, 2007 Eh, I'm not that motivated. I just hate having to do anything with the CV shafts...I'll probably just sell the car with the bad hub and hope it doesn't freeze up in the mean time. Yeah, that nut probably comes from the factory with some sort of adhesive/lock-tite on it. You could probably clean it really well with a good solvent and apply some red locktite on it and it would be about the same. The thing about the nut is the same for the middle of a 2-piece driveshaft, and those get staked as well. Quote
5speedz34 Posted October 19, 2007 Report Posted October 19, 2007 I've never heard of not re-using those nuts? I've re-used them on numerous vehicles and none of my service manuals say anything. There is nothing to them, just nuts. The wheel bearing should come right off the CV, Since it is in front of the strut tower assembly. Basically unbolt get a hammer to loosen the CV shaft off and slide off. They are not that hard., Quote
GutlessSupreme Posted October 19, 2007 Report Posted October 19, 2007 they're technically 35mm for the axle nut, but 36mm works if you can't find a 35. break it loose, remove the 4 rear bolts (careful if it's rusty, don't strip them), and give it a couple of whacks to knock it loose. Careful putting the hub bolts back in too, I've broken two of them. They're $4 a piece from the dealer, I have the part number somewhere if someone needs it. Quote
joey b Posted October 19, 2007 Report Posted October 19, 2007 I would suggest not using an impact to remove the hub to knuckle bolts. I've broken 2 on the same bearing before. Quote
rockfangd Posted October 20, 2007 Report Posted October 20, 2007 overall it is not a difficult job unless you dont take your time and make it difficult Quote
GOT2B GM Posted October 22, 2007 Report Posted October 22, 2007 on reassembly, don't forget about the washer behind the CV axle nut. If it's not in there, the nut won't tighten up on the bearing like it should. Quote
intern8tion9l Posted October 22, 2007 Report Posted October 22, 2007 i've gotten the process of changing a front wheel bearing down to 20-25 mins from the time i jack the car up to the time its back on the ground. it's cake Quote
Nick1234 Posted October 24, 2007 Report Posted October 24, 2007 agreed. spray the back 4 bolts a couple days in advance. i always reuse the nut for the axle. but you may need a long breaker bar. and you need the special socket or star thing (can't think of what is called for the life of me right now) to remove the caliper bracket. Quote
Nick1234 Posted October 25, 2007 Report Posted October 25, 2007 thank you. i was like wtf is my problem. thought of it shortly after Quote
GutlessSupreme Posted October 25, 2007 Report Posted October 25, 2007 T60 torx bit for the caliper bolts. Quote
