Automatic Headlight Sensor?
ok so this would be what im asuming is a sensor that turns on your headlights automaticly when it gets darker. where is this sensor and how hard would it be to change it out? my headlights keep comming on during the day.
I believe it's next to the left hand dash speaker in a CS. You'll have to remove the pad to get to it.
If you want to remove it there should be a fuse for it. At least for mine there is.
well maybe not remove it but just make it work better rather than have my lights turn on druning the day make it work like its supposed to
You can probably take a drill bit and remove some of the plastic around the sensor to allow more light into it. As for the location if I'm not mistaken it should be on the left-ish side of the dash.
Hmm, ok well I know for my car there is a heatsink behind the left side of the dash, when you remove it the DRL's don't come on during the day, however they still automatically turn on at night. Not sure what it's like on yours.
Take compressed air and blow the sensor out..it's just full of dust/dirt. Mine is the same way (turns on during the day)..I don't really care though so I haven't tried fixing it to work properly lol..
would it be that plug/cap looking thing right on the driver speaker with the whole in it?
Yeah it is the middle of my dash by wind sheild on my Silverado.. but thats just a compleatly diff its a little black dome
Did most W's come with this? I was under the impression that it was a newer thing?
It's a Canadian W thing.
Perhaps someone can fill in the details, but I know that the 1st gen GP did not offer a light sensor on the American cars. It had to do with the Daytime running light regulations in Canada. Maybe higher end w's, like the Olds and Buicks were offered with the feature on both sides of the border.
i honestly dont know but i just want it fixed you guys think that a blast of compressed air through the hole opening would clean it?
Yeah if there is a piece of dust or something that is blocking that sensor, the air should clean it off.
All Canadian Ws have the automatic lights standard. It is seperate of the DRL system. It works just like the Twlight Sentinel on the newer cars (except you can't adjust when it comes on and off like the newer cars)..when it's on the headlights and tail lights both come on and they stay on regardless of the headlight switch position. The DRL system just runs the low beam headlights wheneevr the car is on, however my sensor is dirty as well so most of the time all the lights are on..doesn't matter to me though - it's a proven fact driving with the lights on, even during the day, makes your car easier to see; and with all the crazy idiots out there I need all the attention getters I can get.
