MikeP2389 Posted October 13, 2007 Author Report Posted October 13, 2007 hopefully i can get the bastard out Quote
19Cutlass94 Posted October 13, 2007 Report Posted October 13, 2007 It shouldnt be that hard... just spray some shit on there.. let it sit for a while, then go at it. Heres a tip for you as well... when you put the new one in, put a VERY SMALL amount of anti-sieze towards the top of the threads, so if you have to do it again itll come out very easy Quote
MikeP2389 Posted October 13, 2007 Author Report Posted October 13, 2007 well i cant get it out for the life of me. should i cut the wires and get at it with the box end of the wrench. im lost lol Quote
1990lumina Posted October 13, 2007 Report Posted October 13, 2007 I used the boxed end no problem..just slip the wires in the middle of the boxed end..unless the 3100 is different I had plenty of room to put the wiring through..or maybe you have one of those fancey heated O2 sensors..then Idunoo lol Quote
Crazy K Posted October 13, 2007 Report Posted October 13, 2007 i rented the o2 sensor 3 piece set from AZ... and broke one of the parts. hope I can return it. and yes, the closed end of the box wrench does not fit over the heated o2 plug. Quote
MikeP2389 Posted October 13, 2007 Author Report Posted October 13, 2007 yea its a heated o2. the wrench for me barely has enough clearance because its huge. so one of my neighbors whose a mechanic is gonna help me on monday, he said hes got some type of drive that will get it out Quote
5speedz34 Posted October 13, 2007 Report Posted October 13, 2007 When I did the one on the GP I used: PB Blaster, let it sit for 20 min. A bunch of a extensions and a u-joint, and a offset O2 socket. Worked really well. I put alot of torque on it and the ratchet came off the extension, which broke it loose. Real easy actually. I put a Bosch in because I was pressed for time. If I where to do it again I would use Delco or Denso. I haven't had any problems with the Bosch, but I think you won't notice it unless it completely fails on you. Bosch might give shittier readings. Quote
rockfangd Posted October 14, 2007 Report Posted October 14, 2007 lol. I have done many of the 3100 o2 sensors and they can be fun but having long fingers is quite a benefit to me Quote
