MikeP2389 Posted October 10, 2007 Report Posted October 10, 2007 Im going to be putting a new oxygen sensor in my car(3100) this weekend. I was wondering if you guys think borg warner is a good brand sensor because thats what im going to get. Also do all i have to do is rock the engine forward and get a 7/8" wrench and un tighten it and install the new one. thanks Quote
ns87 Posted October 10, 2007 Report Posted October 10, 2007 I've never worked on the 3100, but everything in your post sounds good! Quote
1990lumina Posted October 10, 2007 Report Posted October 10, 2007 I just used a boxed end wrench on the sensor too which worked fine..however you can rent or buy a special O2 sensor socket that makes it easier if the sensor is really stuck into the manifold. Running the motor for a few minutes to warm the manifold will help free the sensor too. Quote
MikeP2389 Posted October 10, 2007 Author Report Posted October 10, 2007 thanks guys.. i wonder if advance will let me rent that socket Quote
Brian P Posted October 10, 2007 Report Posted October 10, 2007 No no Borg Warner sensors are absolute garbage! The ones that even WORK out of the box might last you a year or so. For the minimal extra cost, do yourself a favor and pick up a Delco, or Denso. I think I'd even say take Bosch over Borg warner but I won't say that. Bosch O2's tend to be lazy and wreak havoc on (some) GM's. Quote
Euro Posted October 10, 2007 Report Posted October 10, 2007 No no Borg Warner sensors are absolute garbage! The ones that even WORK out of the box might last you a year or so. For the minimal extra cost, do yourself a favor and pick up a Delco, or Denso. I think I'd even say take Bosch over Borg warner but I won't say that. Bosch O2's tend to be lazy and wreak havoc on (some) GM's. Â Just about to say that. Go Delco! Quote
MikeP2389 Posted October 10, 2007 Author Report Posted October 10, 2007 i cant find any delcos around here so im gonna get a denso instead. 58.99 seem like a good price? or what about standard motor products anyone try their sensors? Quote
Brian P Posted October 10, 2007 Report Posted October 10, 2007 $58.99 is a good price, IMO. Â twost! Quote
19Cutlass94 Posted October 10, 2007 Report Posted October 10, 2007 Has anyone heard anything about the NGK O2's? Quote
ShockTherapy Posted October 10, 2007 Report Posted October 10, 2007 havent seen any thing on the NGK ones, but i'll totally x3 the denso sensors. Quote
Crazy K Posted October 10, 2007 Report Posted October 10, 2007 all i need to say is..... ROCKAUTO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am buying my new DELCO O2s from there. Â Â Quote
Crazy K Posted October 10, 2007 Report Posted October 10, 2007 all I need to say is ROCKAUTO!!!! I am getting my DELCO O2 sensors from there. Â and..... type "rockauto discount code" in a search engine to save 5%!!!!!!!!!!!!!!!!!!! Quote
MikeP2389 Posted October 11, 2007 Author Report Posted October 11, 2007 sadly no one around here carries ac delco sensors. so now i either have to get a bosch one or a Standard motor products one. which one is better. autozone says they have to special order the denso one and i dont wanna wait a week. are bosch o2 sensors really that bad? Quote
19Cutlass94 Posted October 11, 2007 Report Posted October 11, 2007 yes bosch are that bad. The only good ones that they make are the WBO2... why cant you wait a week? Quote
MikeP2389 Posted October 11, 2007 Author Report Posted October 11, 2007 lol im impatient. how about the standard motor parts oxygen sensor that advance sells? Quote
rockfangd Posted October 11, 2007 Report Posted October 11, 2007 SMP sucks and Bosch is even worse. My sensor was a pita on my 300 because i recently installed all new motor mounts and i recently changed my o2 sensor with a bosch and now it is worse than before. get it off rockauto and save time and money Quote
Crazy K Posted October 11, 2007 Report Posted October 11, 2007 SMP sucks and Bosch is even worse. My sensor was a pita on my 300 because i recently installed all new motor mounts and i recently changed my o2 sensor with a bosch and now it is worse than before. get it off rockauto and save time and money QFT! Quote
MikeP2389 Posted October 11, 2007 Author Report Posted October 11, 2007 alright im just gonna order the denso from autozone Quote
MikeP2389 Posted October 12, 2007 Author Report Posted October 12, 2007 so i went out and bought an o2 sensor socket today. btw i ended up ordering the delco from rock auto and its coming in on monday. i went home let the car cool down for like 10mins and then rotated the engine to see if id even be able to get the sensor out. well i couldnt even get it to budge. the socket just sort of slid, so i stopped because i didnt want to strip the threads. is it because the engine was still too hot?? or should i try using some wd40 or pb blaster? i really wanna get this thing out. hey rockfangd wanna help me out since we both live in utica hahah thanks Quote
ns87 Posted October 12, 2007 Report Posted October 12, 2007 it should be easy. I never have an easy time with my car, and it even took me less than 10 minutes Quote
1990lumina Posted October 12, 2007 Report Posted October 12, 2007 It helps if the pipe is warm...dunno if you want it HOT though. And yes, put some pententrate shit on there and let it soak in to free things up. Mine came out with ease but I figure it has been replaced before too. Quote
MikeP2389 Posted October 12, 2007 Author Report Posted October 12, 2007 yea i also bought a 7/8 combination wrench, but it is huge so i hope i have some clearance has anyone had luck with the wrench before? Quote
1990lumina Posted October 13, 2007 Report Posted October 13, 2007 That is how I did mine, with a 12 point boxed end combo wrench, worked fine. Quote
