White93z34 Posted October 7, 2007 Report Posted October 7, 2007 This has been bothering me for a loooooong time now, my passenger side window loves to fall out of track, namely the back of the window comes out first then the bottom of the glass tilts and getting it back up is a large pain. I can put it back in track all i like but it just falls out as soon as I put it down next. i know this is no isolated issue, my friends 92' GPSE does this same thing with the drivers window. DigitalOutsiders Cutlass' drivers window does this too, and i've seen several posts here in the past 2 weeks mentioning this problem. Is it worn out tracks? Worn out nub on the plastic part of the window? I am at a loss here. Quote
GP1138 Posted October 7, 2007 Report Posted October 7, 2007 The nub is probably worn out. I'd take the nub and cut a few strips of electrical tape to size and layer them on, see if that helps make it thicker at all. Quote
boulevard Posted October 7, 2007 Report Posted October 7, 2007 Well that may work but it's usually because a clip somewhere in the track has snapped off. Usually you will not have to replace anything but this clip. It shouldn't be much work from what I hear. See how much a local shop will repair it for. Then ask one of the workers there for their number and call them at home. I bet they all do side jobs for a fraction of the price. That's how I found alot of the guys that work on my car for so damn cheap. Quote
88Regal Limited Posted October 7, 2007 Report Posted October 7, 2007 there is no problem that arrogance and brute force can't solve. Have fun. Quote
w-bodys_are_the_best Posted October 7, 2007 Report Posted October 7, 2007 Judt order new plastic guides from the dealer, I had to on my Z24, they are only like 3 bucks each. Quote
White93z34 Posted October 7, 2007 Author Report Posted October 7, 2007 the plastic guides are integrated into the window, look at the edge next to the door handle. i'll try and get a diagram from the dealership next week. Quote
w-bodys_are_the_best Posted October 7, 2007 Report Posted October 7, 2007 Oh yeah sorry about that, I retract my earlier statement , the 2 doors are integrated it looks like. Quote
5speedz34 Posted October 7, 2007 Report Posted October 7, 2007 So if these "guides" are what goes bad, it means you have to replace the whole glass? Quote
Crazy K Posted October 7, 2007 Report Posted October 7, 2007 yeah. I've said it before, I'll say it again... The tracks tends to flex with age and wear. You can remove the doorpanel and pinch the tracks tighter and they would be fine. mostly it if the front track that spreads out. Imagine the track channel is a "C" you must pinch the c to make it smaller.... then lube it up. Quote
Q-Ball Posted October 7, 2007 Report Posted October 7, 2007 What exactly happens when it goes off track? My passenger window was smashed, and ever since it was replaced it makes this loud click sound when i first start to lower the window. Maybe mine is bad? Quote
1990lumina Posted October 8, 2007 Report Posted October 8, 2007 Mine is loose as hell in the track (passenger side only) I lubed it up this spring and it goes and up and down better but still loose. Too lazy to remove the door panel again lol..winter is coming soon anyways lol Quote
