Green97SL Posted July 7, 2003 Report Posted July 7, 2003 I am sure that many of you know how craptacular the low-beam mini-quads are. i have an extra pair i got from a boneyard. i don't remember where, but i have seen a site/post on the net where someone removed the bulb and siliconed in a better one. is this at all worth it? i guess my main questions would be a: will a 9006 bulb have the same plug as the low beam, and b: will the stock harness be able to handle the current? i'd probably leave the high beams alone, i don't use them that much, and they're bright enough. Quote
Redfox340 Posted July 8, 2003 Report Posted July 8, 2003 There's a couple places on the net that have this update. LukeZ34 first posted the procedure (if my memory still serves me right) on his site: LukeZ34.com Others have followed: W-Body Performance - TTs (Quad Headlight Modification) - Erik Quote
Green97SL Posted July 8, 2003 Author Report Posted July 8, 2003 Something else to keep me occupied on my week off! Quote
luminator94 Posted July 8, 2003 Report Posted July 8, 2003 When I had my Cutty with the mini-quads, I bought a set of Silverstars. I just pretty much twisted off the old sealed bulbs, and the Silverstars hold pretty well w/o the silicone because of the rubber gasket around them. But if you want to use the silicone as a pre-caution, go for it. Other then that, they Silverstars made a noticeable difference, and they never had a problem with the electrical current. Aaron Quote
Guest TurboSedan Posted July 8, 2003 Report Posted July 8, 2003 my old '92 Impala 9C1 had blue & red bulbs put into the sealed high beams, so i don't see why you shouldn't be able to do the same. i think mine were siliconed in. joshua Quote
Heza Posted July 9, 2003 Report Posted July 9, 2003 When I had my Cutty with the mini-quads, I bought a set of Silverstars. I just pretty much twisted off the old sealed bulbs, and the Silverstars hold pretty well w/o the silicone because of the rubber gasket around them. But if you want to use the silicone as a pre-caution, go for it. Other then that, they Silverstars made a noticeable difference, and they never had a problem with the electrical current. Aaron so Aaron...i plan on investing in Silverstars. you really like them?? Quote
sniperi311 Posted July 9, 2003 Report Posted July 9, 2003 ive got the same headlights, the h4s, on my 93 cutlass supreme, and i was wondering if i do replace my bulbs like you guys are talking about am i gonna hafta mess with the tilt, or anything else and what bulb do i use when replacing them the lows not the highs Quote
Redfox340 Posted July 9, 2003 Report Posted July 9, 2003 ive got the same headlights, the h4s, on my 93 cutlass supreme, and i was wondering if i do replace my bulbs like you guys are talking about am i gonna hafta mess with the tilt, or anything else and what bulb do i use when replacing them the lows not the highs No, the tilt won't be affected as long as you don't touch it. You'll be able to remove each lens individually without affect beam direction. - Erik Quote
luminator94 Posted July 9, 2003 Report Posted July 9, 2003 When I had my Cutty with the mini-quads, I bought a set of Silverstars. I just pretty much twisted off the old sealed bulbs, and the Silverstars hold pretty well w/o the silicone because of the rubber gasket around them. But if you want to use the silicone as a pre-caution, go for it. Other then that, they Silverstars made a noticeable difference, and they never had a problem with the electrical current. Aaron so Aaron...i plan on investing in Silverstars. you really like them?? Yep, that's the bulbs that I run in my GTP and in my GA GT. They don't last quite as long as a halogen bulb though, because they burn hotter. But they will still last a long time, just don't touch the bulb when you go to put it in. But as far as my Cutty, I always hated the headlights, especially in the winter! But I think you might be a little bit happier with the Silverstars. Good luck. Aaron Quote
Dannymik Posted August 1, 2003 Report Posted August 1, 2003 They sell the 9006 bulbs on ebay which go in the 4 door cuttys, but this procedure works. I think there is a person on Cardomain that has instructions for the whole procedure. Quote
Redfox340 Posted August 1, 2003 Report Posted August 1, 2003 They sell the 9006 bulbs on ebay which go in the 4 door cuttys, but this procedure works. I think there is a person on Cardomain that has instructions for the whole procedure. Funny... didn't I mention there was a W-Body based site that had the step-by-step procedure? With pictures even... :shock: Side note: Was able to grab on Ebay both pairs of 9005's / 9006's for less than $13. - Erik Quote
