Hootymo Posted July 7, 2003 Report Posted July 7, 2003 i cannot get the one of my rear calipers off, and my parking brake is definitely not on. anyone have any suggestions at all? i tried a torch already, lots of WD-40, but those bolts will not budge. i got the drivers side caliper off without a hassle but the other caliper just will not budge. neither of the bolts will move. any suggestions at all? im desperate, one of my pads on that caliper is completely gone and the rotors are screwed now. also does anyone have the exact size that those bolt heads are? (just so i know im using the right size socket) oh and its the passenger side caliper that is the problem. thanks in advance! Quote
Slade901 Posted July 7, 2003 Report Posted July 7, 2003 Use a breaker bar and a long bar for a lever. Sometimes my breaker bar will almost bend itself so I just use the biggest rachet I got and an extension bar like the 4 way lug nut wrench and I'm successful that way and they don't bend. Quote
GnatGoSplat Posted July 7, 2003 Report Posted July 7, 2003 They are 18mm bolts. I'm sure you're not doing this, but I'll throw it out there anyway: Make sure you're turning them the right direction if you're using an open/box wrench. If you had to push down on the left side, you'll have to pull up on the right side. I usually just put my box end wrench on the bolt and pound away with a big hammer. That usually does the trick. Quote
lukee1982 Posted July 7, 2003 Report Posted July 7, 2003 What i do is put a piece of 2 inch thick walled pipe over my 1/2 drive ratchet. I have a 2 ft long and a 3 ft long piece which ever one will work and have enough hand room. I have also used a a 2x4 and a box end wrench b4 sometype of leverage will get it off Quote
Hootymo Posted July 8, 2003 Author Report Posted July 8, 2003 how can i get the top bolt off? everything is in the way... i can only use an open ended wrench im guessing? and for the bottom bolt, how can i manage to get the leaf spring thing out of the way so the ratchet doesnt have to go onto the bolt on an angle? Quote
Baddflash Posted July 8, 2003 Report Posted July 8, 2003 You should be able to get a rachet and 18mm shallow socket on the bottom without to much trouble try 3/8" drive if using 1/2". If you take off the bracket that holds the brake line it sould get you a bit more room but not much, you'll need and 18mm wrench you might have to buy one; I did. I usually just get a wrench on them and strike the end, also another wrench works good as a snipe. Heat won't do any good cause you can't get to where you need to and if you heat the bolts you'll probably just ruin the slider gaskets if they're any good. Let us know how you make out. Quote
Guest TurboSedan Posted July 8, 2003 Report Posted July 8, 2003 What i do is put a piece of 2 inch thick walled pipe over my 1/2 drive ratchet. I have a 2 ft long and a 3 ft long piece which ever one will work and have enough hand room. I have also used a a 2x4 and a box end wrench b4 sometype of leverage will get it off that's what i would do. let some liquid wrench soak the area over night, and then go at it again. thankfully i have coilovers and don't have to worry about the leaf spring flying out at me! joshua Quote
supreme_style21 Posted July 10, 2003 Report Posted July 10, 2003 I love brakes. Liquid wrench is a penatrating lubricant (not for human uses) :? . I used some heavy duty lubricant and let 'er soak overnight.. that did the trick. Quote
god910 Posted July 10, 2003 Report Posted July 10, 2003 Flame wrench is good too, coupled w/ a BFH Quote
lukee1982 Posted July 10, 2003 Report Posted July 10, 2003 Flame wrench is good too, coupled w/ a BFH A BFH always is helpfull I always call it a persuader hammer however. Quote
lukee1982 Posted July 10, 2003 Report Posted July 10, 2003 will WD-40 work? it may it isn't very good though. O would say if you croil (sp) or something like pb blaster but you can try some wd-40. I hardly ever use it for anything other than starting the lawn mower Quote
god910 Posted July 11, 2003 Report Posted July 11, 2003 ...persuader hammer however In my shop the "persuader" is a 3ft. Snap-on prybar. 8) Quote
