89SupremeCutty Posted October 2, 2007 Report Share Posted October 2, 2007 the lumi ran great for the first 200 miles, then the SES light came on. still runs good and smooth but the code for the SES is for inoperative egr valve or something like that. code p0401. probly a piece of carbon stuck in there. anthything i can do to fix it other than buy a new egr valve? i was also thinking of doing a sea foam treatment this weekend. would that make the EGR worse? i was thinking while im under the hood of doing that along with an oil change and motor flush. thanks for the help. Quote Link to comment Share on other sites More sharing options...
slick Posted October 2, 2007 Report Share Posted October 2, 2007 Carb or throttle body cleaner and a little pipe cleaner (the little wire brush) works wonders. You will want to pull off the EGR and clean it, and spray into the ports running into the intake plenum to clean it out properly. Let it soak in a while, and clean it with the little pipe cleaner brush. Be sure to reset your ecm once your done to reset the code Quote Link to comment Share on other sites More sharing options...
IRONDOG442 Posted October 2, 2007 Report Share Posted October 2, 2007 how do you reset the ECM unplug it ??? Quote Link to comment Share on other sites More sharing options...
slick Posted October 2, 2007 Report Share Posted October 2, 2007 Disconnect the battery or pull the fuse. Quote Link to comment Share on other sites More sharing options...
ns87 Posted October 2, 2007 Report Share Posted October 2, 2007 Sounds like they cleared the code right before you bought it Quote Link to comment Share on other sites More sharing options...
Andrew Posted October 3, 2007 Report Share Posted October 3, 2007 clean it up like Slick said. more often than not that fixes the problem. its better than forking out the dough to buy a new one when you really dont need to! Quote Link to comment Share on other sites More sharing options...
89SupremeCutty Posted October 3, 2007 Author Report Share Posted October 3, 2007 Sounds like they cleared the code right before you bought it couldn't have done that. here in nys, any vehicle 96 or newer with obdII has to go through an inspection computer, which reads wether or not the check engine light is on. and if the battery was disconnected, the codes cleared or the computer was reset, it will automatically fail inspection. the car has to pass something like 5 out of 7 paramaters set by nys. if the battery was disconnected or the codes are cleared or anything like that, the car has to be driven at least 50 miles to reset 5 or all 7 of the paramaters. then it can be re-inspected. besides it took about 150-200 for the light to come on. when i take it off to clean it out, would i have to get a new gasket for it? Quote Link to comment Share on other sites More sharing options...
slick Posted October 3, 2007 Report Share Posted October 3, 2007 Generally yes, you want to. It's only a buck or two. Quote Link to comment Share on other sites More sharing options...
ns87 Posted October 3, 2007 Report Share Posted October 3, 2007 Sounds like they cleared the code right before you bought it couldn't have done that. here in nys, any vehicle 96 or newer with obdII has to go through an inspection computer, which reads wether or not the check engine light is on. and if the battery was disconnected, the codes cleared or the computer was reset, it will automatically fail inspection. the car has to pass something like 5 out of 7 paramaters set by nys. if the battery was disconnected or the codes are cleared or anything like that, the car has to be driven at least 50 miles to reset 5 or all 7 of the paramaters. then it can be re-inspected. besides it took about 150-200 for the light to come on. when i take it off to clean it out, would i have to get a new gasket for it? my bad Quote Link to comment Share on other sites More sharing options...
89SupremeCutty Posted October 3, 2007 Author Report Share Posted October 3, 2007 sweet. i'll get that this weekend along with the oil change stuff. Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted October 3, 2007 Report Share Posted October 3, 2007 Also when you clean it, get a clothes hanger for the plenum ports... does a MUCH better job that just the spray alone. Quote Link to comment Share on other sites More sharing options...
glassvial Posted October 7, 2007 Report Share Posted October 7, 2007 couldn't have done that. here in nys, any vehicle 96 or newer with obdII has to go through an inspection computer, which reads wether or not the check engine light is on. and if the battery was disconnected, the codes cleared or the computer was reset, it will automatically fail inspection. the car has to pass something like 5 out of 7 paramaters set by nys. if the battery was disconnected or the codes are cleared or anything like that, the car has to be driven at least 50 miles to reset 5 or all 7 of the paramaters. then it can be re-inspected. besides it took about 150-200 for the light to come on. when i take it off to clean it out, would i have to get a new gasket for it? Actually it's 70 miles, according to the inspection station around here, fellow NY'er I have the easy solution though, I don't register my vehicles in NY State LOL Quote Link to comment Share on other sites More sharing options...
89SupremeCutty Posted October 7, 2007 Author Report Share Posted October 7, 2007 couldn't have done that. here in nys, any vehicle 96 or newer with obdII has to go through an inspection computer, which reads wether or not the check engine light is on. and if the battery was disconnected, the codes cleared or the computer was reset, it will automatically fail inspection. the car has to pass something like 5 out of 7 paramaters set by nys. if the battery was disconnected or the codes are cleared or anything like that, the car has to be driven at least 50 miles to reset 5 or all 7 of the paramaters. then it can be re-inspected. besides it took about 150-200 for the light to come on. when i take it off to clean it out, would i have to get a new gasket for it? Actually it's 70 miles, according to the inspection station around here, fellow NY'er I have the easy solution though, I don't register my vehicles in NY State LOL i always thought it was 50. Quote Link to comment Share on other sites More sharing options...
