small like knock
when i have been driving for a wile my car gets a small knock when u hit the gas hard like engine pics up but it knocks for like 2 secounds its like a cda cda real fast the car was on the last lil circle for oil when it started to do it.
check your oil level, and maybe do an oil change. mine gets finicky toward the 3000 mile mark, and ticks until i change the oil
I wouldn't owrry too much about it unless it sounds like it's coming from the bottom end of the motor. My 3.1 ticks and slaps like mad all the time with what seems like minimal issues other than annoying the fuck out of me.
ok , its soo hard to describe its like after driving it i stoped a gave her a good shot of gas it knocked and took off, its like if u take your tong and rest the tip at the top of ur mouth and exhale but its quick
It may be a sticky valve? Honestly,I wouldn't worry too much unless you feel your car loosing power. There are some additives at autoparts stores that can help to unstick a valve (or even change the oil earlier than 3000 a couple times).
... on the last lil circle for oil when it started to do it.
this says it right here.
keep your oil level full.
:bash: :bash: I'm sorry to say it but if you ran it low on oil there is a good chance that you've done damage and that tick your hearing is the start of bigger things to come
How long did you run it low on oil? If you ran it long enough, 19GT92 is correct, could lead to bigger problems...
Im pretty sure he has a 3.1L.... Which I wouldn't worry, the bottom end will start hammering sometime soon, why not make it sooner :lol:
well i put 2000 km on it and the knock sound is gone? idono want happened the car is the best 3100 car i ever had it has the most power too its a 97 gutless my last gutless had a 3100 too but the 97 puts it to shame lovesa to do :burnout: with out even any e break! why i dono
