tach off/cant rev high enough.
at idle my tach is reading 2,000 rpm. hooking up to the #1 plug wire with the engine analyzer nets ~600 rpm, the true engine speed.
it will then rev up to the reading of 5500 on the stock tach, which is only giving me about 3500 usable rpm and cutting out around 4100.
i suppose i could start throwing known good parts at it, but where to start? start with an ICM?
Are you revving it in park?
There is a rev limiter in park and neutral at approx 3500 rpm.
The gauge clusters in TGP's are known to go bad.
That is most likely your only problem.
this is tried in gear, not park(trans is cooked so i can rev it as high as i need without moving) :lol:
You might want to check the Idle Air Control sensor. I know one day, the TGP was at idle, but I was going through a parking lot at 25mph.
