4T60-E Shift Kit.
I was wondering where you guys would recommend getting as shift kit for the 4t60-E, the cheapest price I found so far is 84$......Thanks, I hope it doesnt matter if it's 3.4 DOHC or 3100.
it shouldnt matter, because the 4t60-e is the same for both. dont have any experience, although I almost bought one from a guy like a year ago
I am going to have one put it no matter what on the rebuild! :twisted:
if you find a good deal on one, let me know, i would like to get one myself.
Do these things need to be installed inside the transmission?
it depends on what you call inside the trans. as far as i know, with most shift kits, you drop the pan and the valve body, not that much of a PITA.
Just get an adjustable vacuum modulator. You can also shim the accumulator. Ask Sean (99RegalGS) for advice on that one. I don't know much about the 4T60 accumulators.
I thought shimming the accumulator was decided to be bad for the trans?
na, it's nothing different then to find stiffer springs and install. My old Regal is over 180k (as of last march) and is still shifting great with the shimmed accumulators.
EDIT: maybe in the next day I'll attempt to dig up some info for the 4T60 DIY shift kit.
I've been running mine shimmed since 205,000 miles. I just put the harder version in. Check out my thread in this section about it.
which kit did you find? the only one i would use is a TransGo Jr., however, its not going to do much on an e-trans.
X2
get a powrtuner, too :)
