xtremerevolution Posted September 29, 2007 Report Posted September 29, 2007 So I replaced like..3 of them because they were so rotten and dried up that they broke off without much effort when I was putting the rockers in. Yeah, it was pretty bad. Basically what I replaced is from the top of the engine right above the intake manifold, throttle body, and rear valve cover. Are there any others that I need to replace elsewhere? Quote
Psych0matt Posted September 29, 2007 Report Posted September 29, 2007 just find the vacuum ball and see what goes where. i think there are like 4 or 5 main ones, but if you aren't currently having vacuum problems and everything else looks and seems fine, i wouldnt bother. did you get new replacement lines, or did you use some rubber hose or something? Quote
xtremerevolution Posted September 29, 2007 Author Report Posted September 29, 2007 just find the vacuum ball and see what goes where. i think there are like 4 or 5 main ones, but if you aren't currently having vacuum problems and everything else looks and seems fine, i wouldnt bother. did you get new replacement lines, or did you use some rubber hose or something? I got new replacement lines. The old vacuum tubes were VERY badly dried up. They were extremely brittle. Its not that I'm having problems now. I simply don't want to have problems later. Quote
