GutlessSupreme Posted September 27, 2007 Report Posted September 27, 2007 Does anyone have a pic of how these things go through the firewall? I have a bushing/mount plate on the interior side, but there should be a nother bushing/gasket of some kind on the engine bay side, right? I need to see up the gap around them somehow so water doesn't start collecting in there. Quote
Bake82 Posted September 27, 2007 Report Posted September 27, 2007 Does anyone have a pic of how these things go through the firewall? I have a bushing/mount plate on the interior side, but there should be a nother bushing/gasket of some kind on the engine bay side, right? I need to see up the gap around them somehow so water doesn't start collecting in there. Hey Tony, I got lucky and had to of the inside gaskets and used on int he inside and one on the outside. I also got the larger gasket that would go on the black metal sheeting in the engine bay. From what I've noticed, that seems to be water proof, and you would just used this larger gasket on the black metal to seal up the shifter cables. I messed up big time cutting that hole, but I plan on using some kind of RV/make your own gasket kit to cover up the hole. Remember the black platic covering of the cables doesn't move, it';s the inside that does. Try and seal it up with anything as best you can. I can take a picture of said gasket if you like. Quote
