Want torq thurst for my cutlass
Has any one ever sceen torq thrust in the 115M? Or what yr Mustang will work.
I think It was Shawn that said the newer mustang 5 lugs would fit but said the wheels would stick out farther then our wheels.I like those wheels myself.
Cragar has the new style S/S in 16 X 7 and 17 X 7 in 5 on 115mm bolt circle and I believe 38mm offset. I like the Torq Thrusts better but if you're wanting an "old school" looking mag the Cragars or Eagle Alloy are about the only ones I have found. Too bad too because the early W-bodies would look so good with some of the older style wheels. You might contact American to see if the Torq Thrusts can be ordered in a different offset and a true 5 on 115mm pattern.
i have a set of 95 cobra wheels and you will need.... (I've had them on my car before so I know) 3/8" spacers. Spacers are not recommended for any vehicle butthey work if you have the right lugnut style nuts. do not use mag style lugs.
