sunny_8 Posted September 26, 2007 Report Posted September 26, 2007 so I get in and start driving, see the low coolent light flash 5 times every minute. Checked the radiator and overflow tank, both are full. Any ideas ? 3.4 L with 102K Cutlass Supreme Drop Quote
pwmin Posted September 26, 2007 Report Posted September 26, 2007 probably the level sensor on the side tank. theyre notorious for that. Quote
sunny_8 Posted September 26, 2007 Author Report Posted September 26, 2007 so what just add more coolent to the overflow ? Or just leave it.... I am assuming that the side/overflow tank has some sensor in it, which cannot measure correctly right now... Am I correct ? Thanks, Quote
pwmin Posted September 26, 2007 Report Posted September 26, 2007 just leave it if its where its supposed to be. its a square sensor w/ a wire clip the goes around it. plug is on the bottom. its about 3-4 inches down from the radiator cap. http://www.partsamerica.com/ProductDetail.aspx?MfrCode=NIE&MfrPartNumber=DR9203&PartType=1178&PTSet=A im not sure how you test to make sure its just the sensor, but it probably is. i replaced the one on my 96 and it would still read low. started working correctly after a couple days, though. idk why, but they like to not work. Quote
ns87 Posted September 26, 2007 Report Posted September 26, 2007 If its like my car, theres a level sensor on the radiator. Left side if you're facing engine bay, right side of engine bay. Right at the top too! follow the wires Quote
sunny_8 Posted September 26, 2007 Author Report Posted September 26, 2007 cool thanks guys, will check it out tonight. Quote
