amp recommendations?
ok, so i have old-school green infinity reference 4x6 plates in my dash, 5 1/4" reference components in the doors, and kappa 3-way 6x9's in the rear deck. i have to turn the gain on the amp for the 6x9's as to not drown out the smaller speakers, so im going to need to amp the fronts (which i need to do anway as theyre running off the deck). the 5 1/4's are rated at 75W RMS have a 2-ohm voice coil. im not looking for the best stuff, just something decent. i'd like to have it under the driver or passenger seat if possible.
maybe you can lose the plate speakers, put the tweets off the components in the dash where they belong, run the deck power for the front/ rear channel in parallel so it changes from 4 to 2 ohm (is that possible?) and get more power that way if you can for the components (5" woofer, tweeter, and a crossover running them thats 2 ohm, correct?)
thats odd that they are 2 ohm. I have run components off deck power but never but never had to try to get 2 ohms to them so I dont know.
or you can amp the front components and use deck power for the plates and 6x9s. thats what I would do. have the amp in the trunk and everything. a 4 ch amp for sub and components.
Good luck with that. I wanted to do it earlier, but even with the stock seats I didn't have enough room.
that would make 2 ohms, correct, you would lose stereo sound quality if you were to do that. doesn't make sense that they would be 2 ohm 5 1/4s, you sure about that?
Honestly, just go to wal mart and buy like a $50 jenson amp if that's all you need it for, they are fine for regular speakers.
ill have to find my spec sheets, but according to their website, the new references are 2ohm.
ive had good luck with cheapo lighting audio amps. thats what i have running the 6x9's (had it from my last car).
ill prob just end up making a mounting plate behind the rear seat for both amps. the amp i have right now is under the rear seat. i know its not good, but i ran it for a long time in my 96 w/ no problems of overheating and no one ever sits there. i should just move them to the trunk.
you know, them el cheapo amps aren't all that bad...
back in the day when i first got into car audio, I used Jenson, Pyramid, Legacy, and honestly, they worked great for me. I had a little 300 watt pyramid amp powering a single sony xplode 12, and that thing was stupid loud for what it was... honestly it didn't make sense that it was as loud as it was..lol
  boulevard said:
http://www.w-body.com/forum/index.php/topic,63174.0.html
Go here and read the specs for the 4-channel Kenwood Amps that I have. They will run your componets and your subs, all in one amp.
yeah, that would work. im just doing a little research right now, though, as i cant actually buy anything right now. have to order tires for my blazer with my paycheck at the end of this month. if i sell my shotgun, then id have some money at the end of this week, but i doubt itll sell yet. to quote: "drop it to 70 shipped, then i might be interested" :biggrin: nah, i couldnt do that either right now. i dont drive the car much, so its not a priority right now.
The 1000.1? More like 15 lbs, if that.
Again, RF is nothing to get excited about.
I knew someone who had the Phoenix Gold Xenon series amp powering his 6x9s and components and it sounded great. Then again ive had people tell me that PG isnt too great, but IMO his stereo sounded really good.
  • 2 weeks later...
  Ryan from Ohio said:
http://www.caraudiocentral.net/forums/showthread.php?t=8687
You CANT beat the deals on this stuff.
This stuff is top notch and you will not regret any purchase of Elevation Audio products. Especially at these prices!
I think I'm going to buy one of those SQX12 12" subs. Any opinions? I would imagine this might perform better than my Alpine R12...
...Unless someone else wants to sell me a better 12" subwoofer for about $100.
Its apt for a transmission line box FTW
Will be a good sub. Should sound better than a type r.
  • 2 weeks later...
Is Audiomobile still around? That used to be some high $$$ stuff. ADS I beleive is still around. This is mostly high-end equipment though. Depends on what you're building I recon.
i'm just going to use the 4-channel RF from the camaro for now since its stored for the winter now. i may end up running a sub...idk. i have a while to figure it out. the 6x9's do pretty well w/ the bass, though.
