rudefyet Posted July 6, 2003 Report Posted July 6, 2003 I was wondering...which would be better a y-pipe place where the cat used to be that splits into two pipes or two completely seperate pipes running from each header...let me know if you think i should do something else...i'm looking for the one that'll give me the most power gain...i've always thought it would be 2 seperate pipes Quote
Redfox340 Posted July 6, 2003 Report Posted July 6, 2003 If you can find the space from the header to under the car, I'd do the double pipes (with a x-pipe to equalize pressure / sound) from the headers back. But you may run into trouble with routing out of the engine bay and over the suspension in the rear. I would head to a local muffler speed shop to see what they can do for you. It may be just easier with a single with the stock y-pipe split at the rear. - Erik Quote
The Burning Rom Posted July 6, 2003 Report Posted July 6, 2003 You're gonna have some problems routing to seaperate pipes for the exhaust...both in the engine bay, and back by the gas tank. You're also going to have to put a muffler in there somewhere. These cars are LOUD AS HELL without something. Trust me..my muffler broke off once on my LE...almost went deaf driving it home. Quote
Robby1870 Posted July 6, 2003 Report Posted July 6, 2003 Doing two separate straight pipes is basically impossible. Where the driver's side pipe would route would be right where the fuel lines leave the gas tank and fuel filter. I dont think you want the heat from exhaust right by those, and there just isnt enough room. Check out my WWW tab to see what I did with my exhaust, if you want some ideas Robby Quote
rudefyet Posted July 8, 2003 Author Report Posted July 8, 2003 Doing two separate straight pipes is basically impossible. Where the driver's side pipe would route would be right where the fuel lines leave the gas tank and fuel filter. I dont think you want the heat from exhaust right by those, and there just isnt enough room. Check out my WWW tab to see what I did with my exhaust, if you want some ideas Thank you so much!!!...i checked out the link and I like what i saw!...only difference is i'm going to use a resonator pipe for the cat and use dual glass-packed mufflers Quote
Robby1870 Posted July 8, 2003 Report Posted July 8, 2003 Doing two separate straight pipes is basically impossible. Where the driver's side pipe would route would be right where the fuel lines leave the gas tank and fuel filter. I dont think you want the heat from exhaust right by those, and there just isnt enough room. Check out my WWW tab to see what I did with my exhaust, if you want some ideas Thank you so much!!!...i checked out the link and I like what i saw!...only difference is i'm going to use a resonator pipe for the cat and use dual glass-packed mufflers Thanks!! It sounds good too. It has a good deep sound at idle and good note around 2K and good drone on the highway. My rockers made it louder and deeper. You can hear it much past 3K, but it does help low end torque and high end HP Robby Quote
Guest RedCutlassSL Posted July 8, 2003 Report Posted July 8, 2003 i was gonna cut my cat out, but i keep hearing downsides, any advice? Quote
Robby1870 Posted July 8, 2003 Report Posted July 8, 2003 i was gonna cut my cat out, but i keep hearing downsides, any advice? High-Flo cat. What downsides do hear besides emissions Robby Quote
Baddflash Posted July 8, 2003 Report Posted July 8, 2003 The only problem with removing cat is the exhaust smell/emissions. I had a high quality free flow muffler installed in place of cat and 2.5" run to back split infront of rear-suspension with a pair of flow-tech bottles at back. It sounds great at all rpms but sounds mean as hell down low. The high end power has greatly improved and its much more fluid through the rev-range. Modding the airbox or installing COI is almost a must as it adds a lot too. Quote
SleeperRed90TGp Posted July 8, 2003 Report Posted July 8, 2003 Hey Robbie, nice shoe's Good looking exhaust to. Quote
Robby1870 Posted July 8, 2003 Report Posted July 8, 2003 Hey Robbie, nice shoe's Good looking exhaust to. Oh, yeah, I forgot about that pic. I do love those shoes too, I have had them for like 3 years. Anyway, thanks!! Robby Quote
dbtk2 Posted July 8, 2003 Report Posted July 8, 2003 Dual straight pipes is not a good idea on a little V6 like that. You would lose so much backpressure that you would loose power. We have a single 2.5" exhaust on the GTP and it is plenty big. Any larger and we would loose low end torque. (Not that we need all 450lb.ft., but we would lose some) Quote
