digitaloutsider Posted September 22, 2007 Report Posted September 22, 2007 (edited) Edit: March 13, 2017: Added disclaimer for VERY HARD shift kit. Clarified fluid options. Fixed spacing. Free advice: Many transaxle fluids marketed as "Dex/Merc" compatible have changed their formulation and do not conform to previous Dexron specifications. I suggest using ONLY GM approved Dexron VI fluids OR A "Dex/Merc" fluid that conforms to Alison TES-389. Alison TES-389 indicates it is compatible with the old Dexron III standard. Valvoline Dex/Merc is a good option for someone who wants to stay with Dex III. Valvoline MaxLife and other Valvoline fluids seem to be Dex VI compatible now. TES-389 stuff is getting pretty hard to find as of June 2018. Credits: This do-it-yourself method was originally pioneered by members of OKGPC, so they get full credit for coming up with it. I'm simply giving you my twist on it, along with pictures and a more detailed write-up. This is the exact same kit you get from vendors like W-body Store for less than half of the price. Synopsis: Install a shift kit utilizing shims in the transaxle shift pressure accumulator. Difficulty: 3/5. Requires dropping the bottom transaxle pan, removing the shift pressure accumulator, changing the transaxle filter, and refilling the transaxle with fluid. Parts required: The parts you need are determined by whether you want to do the medium (light street/strip) or hard (heavy street/strip) shift kit. There's also an optional spring used to firm up the 1-2 shift (usable with either medium or hard). The shims used are available from McMaster-Carr online. Medium Shift Kit (2) 92415A865 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1/2" Length, 1/4" Screw Size (2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size VERY Hard Shift Kit - Seriously this thing is hard. It will chirp the tires on a 1-2 shift and that means extra transmission wear and tear, especially on the drive chain and final drive unit. Use at your own risk. This is a second warning not to use these shims. Do the medium version. (2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size (2) 92415A869 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1" Length, 1/4" Screw Size Required for both kits8-10 quarts of Dexron VI or Alison TES-389 compliant transmission fluid Transmission filter Optional for either kit 2-3 shift accumulator spring (used to replace the stock 1-2 shift spring). GM part number 24203977. Directions: 1. Raise the front of the car and begin loosening the 10mm bolts on the transmission pan. Loosen the ones toward the back of the car more than the front so the fluid drips toward the long end of the pan. Allow it to nearly fully drain to avoid a huge mess (which is going to happen anyway, it's just saving you at least a little bit of a headache). Remove the pan and clean it off along with the magnet and gasket. 2. With the pan removed we can now access the filter. Pull it straight down firmly, twisting it side to side to break it loose. Change the filter neck gasket if required. 3. Now that the filter is removed, we can now take out the accumulator itself. It's seen below in color, along with the bolts that need to be removed numbered for easy reference. Once these bolts are removed, the accumulator will want to drop down and spill transmission fluid everywhere. Use one hand to hold up the accumulator and another to remove the bolts by hand once they're broken loose. Pull the hard metal lines out of the accumulator using care as not to bend them. Note the location of each metal line. 4. Once the accumulator is removed, place it face-up and remove the remaining bolts. Remove the cover. Inside you'll find two cylinders, both with visible springs. Do one side at a time. Pull up on a spring and remove it. Try to take out only the small spring and the metal plate it sits on, leaving behind the rod and large spring. Put one of the longer shims at the bottom of the rod. If you're using the optional 2-3 spring, and you're working on the 1-2 accumulator, remove the small spring from it's base, and press the new spring onto it. Reinstall the small spring and base onto the rod. Add a short shim in the middle of the spring. Repeat for the other side. 5. Reinstall the cover to the accumulator. Bolt it back into the transmission, using extreme care to reinstall and reseat the hard metal lines. Make absolute certain the lines are reseated properly. If they're not, you'll be left with a slipping transaxle that burns up clutches.. In case you forgot where the lines go, here's a picture: 6. Reinstall the transaxle filter. Put the pan cover back on, and fill the transaxle with approximately 8-10 quarts of ATF, depending on how much fluid you lost. Once you're sure you have the proper fluid level, take the car for a spin and make sure that it's not slipping. If it's all good to go, enjoy your new shift kit! Your wallet will thank you for it! Edited June 7, 2018 by digitaloutsider FrankRat 1 Quote
Andrew Posted September 22, 2007 Report Posted September 22, 2007 that is a good write up!! I did this shift kit, though it is from ZZP but its the same thing. It would have been really helpful if they included a picture like that to show which 4 bolts hold up the accumulator. i had to remove them all to get it down! I would not recommend the hard shift kit for daily drivers. the medium is quite good enough, trust me!! Quote
Mach 5 Posted September 22, 2007 Report Posted September 22, 2007 Will this work for the 440t4 trans or the 4t60? Good work. Should make this a sticky or something. Jarek Quote
pwmin Posted September 22, 2007 Report Posted September 22, 2007 Will this work for the 440t4 trans or the 4t60? Good work. Should make this a sticky or something. Jarek it should, but im not sure what size shims you would use. shift kits work pretty good on non-e trannies, too. Quote
slick Posted September 22, 2007 Report Posted September 22, 2007 There's a nice write-up on bonnevilleclub.com also on the shift kit procedure as well. Anyways, good job Shawn. Quote
digitaloutsider Posted September 22, 2007 Author Report Posted September 22, 2007 Will this work for the 440t4 trans or the 4t60? Good work. Should make this a sticky or something. Jarek it should, but im not sure what size shims you would use. shift kits work pretty good on non-e trannies, too. As far as I know, 440T4's/4T60's/4T60-E's don't have the shift pressure accumulators that the 4T65E's do. Shift pressure is controlled through the vacuum modulator. Quote
Euro Posted September 22, 2007 Report Posted September 22, 2007 Wow nice writeup!! too bad I don't have enough mechanical motivation to do this....heh Quote
rockfangd Posted September 22, 2007 Report Posted September 22, 2007 very nice write up and great pics Quote
pwmin Posted September 22, 2007 Report Posted September 22, 2007 the new vacuum modulators are adjustable, so that might give you enough extra. Quote
99RegalGS Posted September 23, 2007 Report Posted September 23, 2007 As far as I know, 440T4's/4T60's/4T60-E's don't have the shift pressure accumulators that the 4T65E's do. Shift pressure is controlled through the vacuum modulator. The 4T60/440T4/etc.. do have shift accumulators. The accumulators have nothing to do with line pressure during shifts, they just absorb the initial pressure burst to make smoother shifts. I did shim them in my old Regal, with a slight difference. The accumulator housing in the 4T60 actually looks identical to the 4T65 trans. but the internals are different. The 4T60 accumulators only use 1 spring vs 2 on the 4T65. Anyway, the shift kit for the 4T60 just uses shims under the springs in the accumulators. Just find a washer that fits into the base of the accumulator w/o too much play. Just add more washers for more shift firmness. IIRC I used 3 washers (they were thin washers) and it was a small, but noticeable difference. Quote
digitaloutsider Posted September 23, 2007 Author Report Posted September 23, 2007 As far as I know, 440T4's/4T60's/4T60-E's don't have the shift pressure accumulators that the 4T65E's do. Shift pressure is controlled through the vacuum modulator. The 4T60/440T4/etc.. do have shift accumulators. The accumulators have nothing to do with line pressure during shifts, they just absorb the initial pressure burst to make smoother shifts. I did shim them in my old Regal, with a slight difference. The accumulator housing in the 4T60 actually looks identical to the 4T65 trans. but the internals are different. The 4T60 accumulators only use 1 spring vs 2 on the 4T65. Anyway, the shift kit for the 4T60 just uses shims under the springs in the accumulators. Just find a washer that fits into the base of the accumulator w/o too much play. Just add more washers for more shift firmness. IIRC I used 3 washers (they were thin washers) and it was a small, but noticeable difference. Ah! Thanks for that, Sean! Quote
99RegalGS Posted September 23, 2007 Report Posted September 23, 2007 Yeah, I just wish I had taken pictures of when I did it so I could have done a writeup for the 4T60!!! Quote
19GT92 Posted September 26, 2007 Report Posted September 26, 2007 Yea I was In Contact with Zoommer At ZZP email and was told that there shift kits would work with the 4t60 trans Quote
AWeb80 Posted February 21, 2008 Report Posted February 21, 2008 ok....by looking at teh accum pic, how do you know the diff between the 1-2 and 2-3 accumulators? Quote
5speedz34 Posted February 21, 2008 Report Posted February 21, 2008 ok....by looking at teh accum pic, how do you know the diff between the 1-2 and 2-3 accumulators? The part that they sit in seem to say "1-2" and "3-4." Quote
digitaloutsider Posted September 15, 2010 Author Report Posted September 15, 2010 Updated to clarify the proper fluids. Fixed a typo. Moved thread. Quote
gdcastro Posted September 29, 2010 Report Posted September 29, 2010 Hi. I am installing the kit this weekend. I also got 1 2-3 AC Delco Spring. Do i need only 1 of this, to place on the 1-2 position, or do i need to replace both the springs on the 1-2 and 2-3 positions? Quote
gdcastro Posted October 9, 2010 Report Posted October 9, 2010 Just installed the transgo kit with the optional 2-3 accu spring for the 1-2 chamber. Very happy with it. redgrandprix 1 Quote
aj510 Posted February 22, 2011 Report Posted February 22, 2011 would like to do this shift kit on my 97 gtp but its a little confusing. y does it show that you need 2 of each spacer and is ther 1-2 shift spring the same spring used for the 2-3 shift? also y does it show 2 different lengths for the spacer? "(2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size (2) 92415A869 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1" Length, 1/4" Screw Size" does the longer one go in the 2-3 shift and shorter in the 1-2? one last thing, which is which shift? how do you tell what pocket is the 1-2 shift and the 2-3 shift? Quote
Andrew Posted February 23, 2011 Report Posted February 23, 2011 would like to do this shift kit on my 97 gtp but its a little confusing. y does it show that you need 2 of each spacer and is ther 1-2 shift spring the same spring used for the 2-3 shift? also y does it show 2 different lengths for the spacer? "(2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size (2) 92415A869 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1" Length, 1/4" Screw Size" does the longer one go in the 2-3 shift and shorter in the 1-2? one last thing, which is which shift? how do you tell what pocket is the 1-2 shift and the 2-3 shift? use the shorter spacers on the 1-2 shift. In the pic that shows the numbered bolts you can also see the housing stamped 1-2 an 2-3. Quote
Imp558 Posted January 22, 2017 Report Posted January 22, 2017 I actually like Rats, but not that one... Quote
digitaloutsider Posted March 13, 2017 Author Report Posted March 13, 2017 This thread seems to be getting linked from another forum. Please keep in mind that this writeup was done nearly a decade ago. I did edit some of the post for clarification on fluids and added a disclaimer. Seriously, I wouldn't do the "hard" shift kit unless you really like hearing the dashboard crack on WOT shifts. Quote
Imp558 Posted March 13, 2017 Report Posted March 13, 2017 Really have to wonder how that post about Rats got in there? Must have been in the wrong thread, probably using mobile. That's still a good write-up. Psych0matt and digitaloutsider 2 Quote
