1979lee Posted September 20, 2007 Report Posted September 20, 2007 Hi all, i have no brake lights on my 98 lumina , got turn singals and running lights, backup lights but no brake lights, Ideas??? bulbs and wireing look good, hell it looks like there the original bulbs thanks Quote
slick Posted September 20, 2007 Report Posted September 20, 2007 Check your brake light switch. Quote
1979lee Posted September 20, 2007 Author Report Posted September 20, 2007 ok will do, not i checked the brakes again and my 3rd brake light works , but not the lower 2??? Quote
slick Posted September 20, 2007 Report Posted September 20, 2007 Could be a bad ground in the brake light harness. Maybe someone can find a diagram and post it up? Quote
1979lee Posted September 20, 2007 Author Report Posted September 20, 2007 hope thats all it is, oh yeah tryed em just now and they work Quote
1979lee Posted September 20, 2007 Author Report Posted September 20, 2007 i just did a light check, tried the turnsignals ect and when you move the turn signals the brake lights cutout what the hell is up with that? Quote
Crazy K Posted September 20, 2007 Report Posted September 20, 2007 GUYS!!!!! give him the correct answer!!!! IT is a bad turn signal switch. IMO It could be dismantled, contacts cleaned/ bent to retension, re-lubricated, and reinstalled. if that is beyond your abilities... get a new switch. Quote
DiscoStudd Posted September 20, 2007 Report Posted September 20, 2007 3rd brake light lighting up and not the lower 2 = bad signal switch http://tss.likeabigdog.com for your disassembly instructions. Thank you, drive through... Quote
Pontiac6KSTEAWD Posted September 22, 2007 Report Posted September 22, 2007 Thank you for the info. I have seen probly 30 1.5 gen w-bodys, and full size GM vans with this problem. Now I know how to tell em to fix it on the W-body, is it the same problem on the full size GM vans. Quote
LumiDriver Posted September 26, 2007 Report Posted September 26, 2007 Yeah, stupid fucking TSS. But, at least I can pull forward on it to make the lights go on The part is about 52$ at the local autozone here, you just need to be careful if you replace it (Airbag). Quote
CanadianRegal Posted September 27, 2007 Report Posted September 27, 2007 I have the same problem with the Regal. It's the turn signal switch alright. It's 60 at the dealership. Quote
DiscoStudd Posted September 28, 2007 Report Posted September 28, 2007 I have the same problem with the Regal. It's the turn signal switch alright. It's 60 at the dealership. Follow my instructions. Most of the pics are from my old Regal, so you'll feel right at home. http://tss.likeabigdog.com Quote
1979lee Posted September 28, 2007 Author Report Posted September 28, 2007 well i got the switch replaced today, but the new one is crap, so looks like i'm still screwed till the shop, can replace the bad one on monday... at least i have brake lights know, but they still go out whey you use the left turn signals, damn after all of this man this car is starting to bug me thanks for the info DiscoStudd , very helpfull,btw what happened to the gm service info site did the change the address becasus its been dow know for at least a weeks http://65.175.136.163:9001/servlets/Home (dosent work) Quote
