NEEDED: 1988 C100 engine harness connector wiring diagram!!
Hey Guys!
I NEED the wiring diagram for a 1988 Cutlass Supreme C100 engine harness bulkhead connector. I need to know what the wire colors are! it is not in my 89 FSM and I don't have access to alldata! Hoping somebody can help me out!
Your service manual should have it.
Are you sure you have both volumes?
Find Taylor on the other w-body forum, he's gotta have it. Riven5415 should be his s/n
3100MPFI.
There's only 1 volume for 1988 and 1 for 1992...I had both, but only have 1992 at the moment and the neighbor lady has it. I'll get it tomorrow.
Are these what you're looking for?
I have those(they connect at the ECM, I'm looking for the firewall connector for my 88.
I have the 89 Manual but it just gives me colors, but no description of that the wires are.
That would be awesome if you can get me the 88 one! I found the 92 in my manual, so I don't need the 92 diagram anymore, only the 88!
thanks!!
http://www.savefile.com/files/1068273
Here you go ... I scanned 4 sheets from the wiring section. The sheets show the connection to the c100 block.
The pdf will print on letter sized paper.
Thanks a million!! helps me with my wiring emmensly!!
