xtremerevolution Posted September 14, 2007 Report Posted September 14, 2007 So my interior console lights are starting to go POOF, particularly on my climate control deck. I've already lost lighting to 6 of the buttons. Is there some way to open them up and change the light bulbs? I'd love to put some blue LEDs in there, or at least get them lit up again. Quote
Crazy K Posted September 14, 2007 Report Posted September 14, 2007 I don't know on regals... but many such devices use bulbs that are soldered in, and could be replaced with new ones from radioshack, if you can solder. Otherwise... in my cars, I run the interior lights at a minimal setting, meaning the less voltage running thru the lights will make them last longer. say about 1/2 of full brightness. This is not an issue in the cars I have equipped with HUDs... cause I can run dark with those! Quote
xtremerevolution Posted September 15, 2007 Author Report Posted September 15, 2007 I don't know on regals... but many such devices use bulbs that are soldered in, and could be replaced with new ones from radioshack, if you can solder. Otherwise... in my cars, I run the interior lights at a minimal setting, meaning the less voltage running thru the lights will make them last longer. say about 1/2 of full brightness. This is not an issue in the cars I have equipped with HUDs... cause I can run dark with those! I was thinking that was the case, and that I should just get some blue LEDs and re-solder them on where the old bulbs were... That would be pretty awesome I would think... Quote
GtipGary Posted September 15, 2007 Report Posted September 15, 2007 Yes indeed! Let me know how that goes, because i was thinking about doing the same thing myself Quote
digitaloutsider Posted September 15, 2007 Report Posted September 15, 2007 Trust me, you don't want blue backlighting in anything on your dashboard. Worst decision I ever made when it came to aesthetics on the car. No color but blue shows though. No red on your HVAC, no orange or red on your tach. Keep the stock lighting colors. Quote
xtremerevolution Posted September 15, 2007 Author Report Posted September 15, 2007 Trust me, you don't want blue backlighting in anything on your dashboard. Worst decision I ever made when it came to aesthetics on the car. No color but blue shows though. No red on your HVAC, no orange or red on your tach. Keep the stock lighting colors. Hmm... In that case, I might want to just pull a unit from the junkyard to experiment with. Quote
GtipGary Posted September 16, 2007 Report Posted September 16, 2007 Decided id put the side view first, cars kinda dirty. Thats what it looks like with a blue cluster (in my car) I like it... I wanna do the rest blue! Quote
xtremerevolution Posted September 16, 2007 Author Report Posted September 16, 2007 That looks pretty badass. I think if you can get the color right and find a way to separate the light paths, you can make blue + red + green work together. Quote
