meltboy1 Posted September 11, 2007 Report Posted September 11, 2007 I just disconnected the wire to the trunk pop, but before it would just randomly open.... Me and my friends sat out there one day, cuz sometimes I would go outside and my trunk would be open and I was like WTF?... so we sat there, and it would just randomly pop sometimes... any ideas as to why this might happen? Quote
SigEpCutlass Posted September 11, 2007 Report Posted September 11, 2007 IIRC, the trunk opener is connected to the Park/Neutral Saftey Switch. That's probably the source of your issue. Quote
Guest Posted September 11, 2007 Report Posted September 11, 2007 Unless the interior switch is stuck in a closed state, the tranny position switch couldn't be the problem. Was it a factory option or did you add it? the wire going to the trunk is just the ground, it's gotta be getting powered somehow. try replacing the switch Quote
93CutlassSupreme Posted September 11, 2007 Report Posted September 11, 2007 do your power locks also go apeshit and lock and unlock rapidly by themselves? Quote
meltboy1 Posted September 11, 2007 Author Report Posted September 11, 2007 do your power locks also go apeshit and lock and unlock rapidly by themselves? ya, I forgot to mention that part, sometimes the car would lock/unlock itself, but only when the wire connected to the switch on the trunk was plugged in... Quote
93CutlassSupreme Posted September 11, 2007 Report Posted September 11, 2007 do your power locks also go apeshit and lock and unlock rapidly by themselves? ya, I forgot to mention that part, sometimes the car would lock/unlock itself, but only when the wire connected to the switch on the trunk was plugged in... mine did the same thing. i believe this problem is in the keyless entry box in the car. I unplugged that and these problems went away. Quote
meltboy1 Posted September 11, 2007 Author Report Posted September 11, 2007 keyless entry box eh.. I don't think I have that in my 90 TGP, I don't think that was an option... but it's a good thought, and something I considered. Quote
Guest Posted September 11, 2007 Report Posted September 11, 2007 whoops! forgot about the keyless entry.. it was definetly an option, and one that I would look into. Quote
rockfangd Posted September 11, 2007 Report Posted September 11, 2007 It really sounds like the keyless entry module though, check in the trunk near the antenna for a single black wire Quote
digitaloutsider Posted September 11, 2007 Report Posted September 11, 2007 keyless entry box eh.. I don't think I have that in my 90 TGP, I don't think that was an option... but it's a good thought, and something I considered. It was standard on your car. Quote
Andrew Posted September 12, 2007 Report Posted September 12, 2007 mine randomly unlocks itself all the time, so i pulled the fuse for the power locks. only once its popped the trunk on me, and i was at the mall! great timing you stupid W.... luckily my subs were still there. anyway, im guessing i have the same problem then. i wasnt sure if it was the remote control door lock receiver or the bcm. i guess ill try the rcdlr first. Quote
Crazy K Posted September 12, 2007 Report Posted September 12, 2007 WELL... I have had this issue with my 91 international sedan. I got locked out of it, and the car still has no keys. I wound up punching out the lock on the smashed door and getting back in... except it locked itself again last night! @!%$^!*%$*!@# Quote
Andrew Posted September 12, 2007 Report Posted September 12, 2007 I got locked out of it, and the car still has no keys. I wound up punching out the lock on the smashed door and getting back in... except it locked itself again last night! @!%$^!*%$*!@# LOL!!!! Quote
