vancutlass Posted September 8, 2007 Report Posted September 8, 2007 I'm lookin to do an engine swap on my 1990 cutlass supreme vert. I'm looking for something powerfull that will turn my car into a sleeper. What do you guys recommend and also keep in mind that I have digital dash and in board computer so will compatability be an issue? Much appreciated, Thanks. Quote
ManicMechanic Posted September 8, 2007 Report Posted September 8, 2007 Ooh a '90..I need VIN info? Quote
gp90se Posted September 8, 2007 Report Posted September 8, 2007 the subframe in your car wont take a 3.4 without welding, or swapping out. the supercharged 3.8 (l67) will bolt in and work with a little wiring. the turbo prix 3.1 is all bolt in as well. just remember the stock 4t60 won't take tons of power. spray it with a 50 shot, it'll pickup Quote
joey b Posted September 8, 2007 Report Posted September 8, 2007 the subframe in your car wont take a 3.4 without welding, or swapping out. the supercharged 3.8 (l67) will bolt in and work with a little wiring. Pretty sure it is the other way around Quote
gp90se Posted September 9, 2007 Report Posted September 9, 2007 the subframe in your car wont take a 3.4 without welding, or swapping out. the supercharged 3.8 (l67) will bolt in and work with a little wiring. Pretty sure it is the other way around the LQ1 uses mounts on subframes 91+, 88-90 don't have accommodations for it Quote
SigEpCutlass Posted September 10, 2007 Report Posted September 10, 2007 If you want swap advice specific to a '90 vert, you might want to talk to Pabz. Pabz currently has a engine swap going on with his '90 vert, but I can't remember what he's swapped under the hood. Quote
Bake82 Posted September 10, 2007 Report Posted September 10, 2007 the subframe in your car wont take a 3.4 without welding, or swapping out. the supercharged 3.8 (l67) will bolt in and work with a little wiring. Pretty sure it is the other way around the LQ1 uses mounts on subframes 91+, 88-90 don't have accommodations for it I'll atest to that! My 88 subframe is different than the 92. There is an extra mount at the back passenger side of the subframe, which I assumed is to mount the 3.4 DOHC. If you want swap advice specific to a '90 vert, you might want to talk to Pabz. Pabz currently has a engine swap going on with his '90 vert, but I can't remember what he's swapped under the hood. Pabz did a 3400 5 speed swap into his car. I do believe he has it finished as it just putting the final touches on it(ie shift boot and knob, little htings. Quote
Andrew Posted September 11, 2007 Report Posted September 11, 2007 im going to withhold my response until the original poster gives his definition of "powerful" Quote
