3.4 Olds Cutty Drop Starter Replacement
So I have an issue with my car, sometimes it does not start untill I turn the key 5 times.
I want to replace the starter, read some posts saying its better to get a starter for a different car, and then use it as it has higher torqure and is smaller ? Saw a post that said use a 99 chevy malibu starter.
Is this true ? Can I use this and should I do it ?
Also how long does it take to do ? I guess take the oil flter off, undo the oil cooler and starter and replace, but not sure, never done one.
Also any brands to avoid ? I was going to autozone to get one...figured I would ask..
Thanks,
I would look on e-bay, or get a used one from a wrecked 99 and newer 3x00 car/van.
are you sure it is the starter?
not sure if its the starter, but I would think it is....no anti theft light.....So what just get the starter for our car ? or a newer 3x00 car ? What kind people using ?
thanks,
if the starter actually is the problem, why not get the correct one?
my Cutlass has 130,000 miles on the original starter
Ive got 110000 on my gp LQ1 and mine does the exact same thing. Most of the time it starts just fine. Then other times i get in and click, click, click, vroom.
Yes, any of the newer 3x00 (3100, 3400) starters should work. Try for 99+ as well, it's smaller and higher torque. Make's getting it back up in there a lot easier.
so what kind of car has the 3100 or 3400 starters ? Anyone been using a specific one ?
Thanks,
cool thanks, will pick up a 02 intrigue starter....
Is Autozone ok for this ? or do their starters have too many problems ?
As said, check ebay first, or even your local junkyard. It'll be Genuine GM and a lot cheaper. I got mine off ebay, it came off a 30k mile 05 Impala 3400.
ok then to confirm a 05 Impala and a 02 intrigue will be a replacement for a 95 3.4L DOHC.
Correct ?
i picked up one on egay off a 2001 lumina for $20 + shipping. they work on the 2.8, 3.1, 3.4, 3100, 3400, blah. i have it on the 91 3.1 in the 94 euro, and i'll probably swipe it over to the TGP shortly.
So far this is what I find that will be a EXACT fit on a 95 3.4L DOHC - CAN SOMEONE PLEASE CONFIRM ?
2001 lumina
2005 Impala 3400
2003 V6 Grand Am
2001 malibu with a 3100 or a 2001 impala with a 3400
Wanna order one today ......thanks,
  • 2 weeks later...
So I got my new started, off a 05 Impala, 3.4 L engine. Much smaller
Bad part is that the post on the solonoid, is broken to some extent. It got damaged shipping, so I put the plastic back on and then jbweld all over it. I hope it does not go into the solonoid.....
installed it and it works ......sounds funny though, a lot deeper sounding than before. And it takes about 2 seconds more to start. Actually it now does sound like an impala starting...
