Poor runability in rain !
Hello ... For some time now I have noticed that when I drive in the rain car misses and stumbles.... like No fuel and or spark issue
( seems like a rev limit is turned on ??? ) after rain stops and road somewhat dry the issue fades away.... ( No code was or has set ) on all dry days Normal codes at all ever ! .
I do have a Tech1a and a master tech ( bidirectional tool ) no freeze frame or codes recorded and for some reason the rain is so unpredictable here and don't wish to leave my scan tool in car while I work.
3100 V6 vin# 1g3wh12m45d345939
I did try the water hose to ecm at engine compartment was unable to replicate the issue ' note 'at no time did a code pop up while the issue roared its head also to give a more detail when issue come up in the rain while you throttle it up 25- 30 slowly will pick up speed but give it too much tps goes to back fire and shaking and slows down to a crawl.. I'm not a parts replace and deal with facts and good scan tool inputs.... I find no out of limits inputs / outputs to warrant ecm replacement ?
I got this car from a owner with a repair Bills in 2 mo 800.00 ... all GM parts coils , module , fuel pump , tps. sad but parts have already been thrown on with no good checks and issue still there . I paid 500.00 for the car and shes a bute! I do have a rag top also and have just seen this site , I'm a noob and I have read some replies to you new bee's BE KIND ! LOL with you remarks ! yes I will send pic's ! and Thanks to your ADMIN on letting me Join !
Chris
i would spray the coils and icm directly with water, as well as try to get the plugs themselves wet, you could have a cracked ceramic on a plug.
3100 V6 vin# 1g3wh12m4Sd345939
[edit]-Corrected - VIN researcher ;)
The plugs were checked and 3 set were installed .... water test has failed several times to no aval but rest assure if it rains hard and you hit a puttle you wont get there fast..... the mostlikly parts I have and would of thought has been checked ..... given the humidity here in Florida I was leaning to the internal parts of the ecm But I must surcome to go get the ECM and swap out the e prom
I'm not sure if 1995s had swappable e-proms...I think you have to replace the entire unit...The 1994-95s were a little odd in that manner being OBD 1.5.
Ill go get a ecm with same part # and replay to the issue again if don't fix it understand I'm not a parts replacer i would of liked to see data or glitches in the live data stream
WELCOME!!!!
I caught that VIN glitch is my first 5 seconds of looking at the first post. Thanks for the VIN info for our records! please look at the door and get the month/year of build!!!
The 1994-1995 3.4 PCM uses a prom chip still, but it is still an obd 1.5 car. I think you should inspect the PCM case for rust or holes first. (btw, I do have a spare set of this ecm and a few chips)
Here is what you should do. open the hood, and spray each part with a hand held water bottle, find out what part doesn't like getting wet! every part!
WELCOME!!!!
I'm guessing 11/94 or 12/94... lol
well I will get the ecm and the man date is 12/ 94...... no water is in or no rust ... ( Checked after your post )I scratch my head on when the issues start to happen the live data reads nor and outputs and in range pulse with to injectors and good also o 2 freezes to 500 `~~ 600
