Panther15 Posted August 30, 2007 Report Posted August 30, 2007 lately my engine has been idling very high for some reason which i cannot figure out. Doesnt seem to have a throttle cable issue, not sure what it could be. any help would be greatly appreciated. i gotta change the water pump this weekend anyways, one of many other things wrong with this 158 thousand mile motor lol. Quote
Pabz Posted August 31, 2007 Report Posted August 31, 2007 check your iac (idle air control valve) on the throttle body. Clean it out, it might be getting stuck. Otherwise check for vacuum leak. Quote
Q-Ball Posted August 31, 2007 Report Posted August 31, 2007 Did you disconnect the battery? Try and idle re learn. I didnt do this for about 1.5 years. The gas i save now! 1100 rpm idle down to 500 rpm idle! How high is your idle? does it get any better after you drive it and warm it up? Quote
Panther15 Posted August 31, 2007 Author Report Posted August 31, 2007 usually if i drive it for a bit it goes down. but i will go ahead and check that valve and what not. might end up doin the battery idea. Quote
Pabz Posted September 1, 2007 Report Posted September 1, 2007 usually if i drive it for a bit it goes down. but i will go ahead and check that valve and what not. might end up doin the battery idea. if you clean the IAC, do the idle relearn. Quote
Doug Goodwrench Posted September 6, 2007 Report Posted September 6, 2007 I had the same problem on a '93 Olds VIN T (3.1L). When I hooked it to a computer... it turned out to have 5% throttle angle at an idle. Disconnecting the battery would fix the problem for a number of drives, but I replaced the TPS, and now have no problems. The other guys are right though, IAC and vacuum leak are the first 2 things you should check. Later. Quote
ns87 Posted September 6, 2007 Report Posted September 6, 2007 after that also check the engine's coolant temperature sender. That also leads to a high idle if it isn't working Quote
WC-Frogger Posted September 6, 2007 Report Posted September 6, 2007 I have had a sim issue ...3 time the pvc line broken , valve bad or dirty iac if you can get a TECH 1a bidirectional scan tool look at the counts for tps to valve counts along with requested iac , if you computer is asking for lets say 10 counts your iac output should be with in 2 counts if it is you have a vac leak and look hard at pcv and the plastic hose and rubber hose ( ALL ) ..... Quote
R Dubya Posted September 7, 2007 Report Posted September 7, 2007 so will the idle drop, but as soon as you tap or press the gas jump back up and then take a long time to drop back down, or is it just stuck high? Quote
Panther15 Posted September 9, 2007 Author Report Posted September 9, 2007 if i hit the gas it stays high for alittle bit, then slowly goes down basicly what you said above. 2 posts up Quote
R Dubya Posted September 9, 2007 Report Posted September 9, 2007 it's either a massive vacuum leak, which you should check over anyway, but more than likely this problem is caused by tired injectors. I had the exact same problem with my 3.1 turbo engine. New injectors smoothed out the idle and the throttle response big time. Quote
