LuminaMan93 Posted August 29, 2007 Report Posted August 29, 2007 The check engine light came on for the first time in the Impala last Monday. I went to autozone and had them pull the code for me. It came back P0480- malfunction in the control circuit for cooling fan 1. I checked where the wire plug into the fans but didnt see anything. I think it is a just a bad connection because the check engine light will go out then come back on the next day. The temperature is reading halfway on the gauge and runs hotter when the A/C is on. I had to turn the A/C off because it was almost in the red driving home on a hot day sitting in traffic. I was wondering if there is a fuse or another connection that I should check? FWIW its a 3800 Series II. Thanks in advance. Quote
xtremerevolution Posted August 29, 2007 Report Posted August 29, 2007 The check engine light came on for the first time in the Impala last Monday. I went to autozone and had them pull the code for me. It came back P0480- malfunction in the control circuit for cooling fan 1. I checked where the wire plug into the fans but didnt see anything. I think it is a just a bad connection because the check engine light will go out then come back on the next day. The temperature is reading halfway on the gauge and runs hotter when the A/C is on. I had to turn the A/C off because it was almost in the red driving home on a hot day sitting in traffic. I was wondering if there is a fuse or another connection that I should check? FWIW its a 3800 Series II. Thanks in advance. LOL Sounds exactly like the same problem I was having with my Series I 3800. There should be a fan dedicated to turn on when your A/C turns on. For mine, the fuse had gone bad because of a short circuit on the wire right next to the fusebox. I'd check that out first. Quote
