xtremerevolution Posted August 27, 2007 Report Posted August 27, 2007 6 months on a brand new engine torque mount and the bolt rips clear through the bushing. Is this normal? I really need one with polyurethane bushings. Quote
1990lumina Posted August 27, 2007 Report Posted August 27, 2007 Wow it sure rusted fast in 6 months Quote
xtremerevolution Posted August 27, 2007 Author Report Posted August 27, 2007 Wow it sure rusted fast in 6 months I don't think it was ever really painted, and its just surface rust. I can wipe it off pretty easily. Quote
1990lumina Posted August 27, 2007 Report Posted August 27, 2007 Well regardless that mount shouldn't have fallen apart like it did. Maybe there was a flaw in the rubber...or you 3.8 has that much powa! Quote
xtremerevolution Posted August 27, 2007 Author Report Posted August 27, 2007 Well regardless that mount shouldn't have fallen apart like it did. Maybe there was a flaw in the rubber...or you 3.8 has that much powa! LOL. I'm guessing its pulling 230-235 lb-ft of torque, which is about the same amount that a Series II 3800 pulls. The only difference is that an SII 3800 has two engine torque mounts, and I only have one... Quote
Robby1870 Posted August 27, 2007 Report Posted August 27, 2007 Wait, that failed on the "frame" end? By "frame" end I mean the end that attaches near the radiator. Usually they fail on the engine end first. Probably a flaw in the rubber. Warranty? Quote
xtremerevolution Posted August 27, 2007 Author Report Posted August 27, 2007 Wait, that failed on the "frame" end? By "frame" end I mean the end that attaches near the radiator. Usually they fail on the engine end first. Probably a flaw in the rubber. Warranty? Nah, that failed on the engine end. Still, a ripped bushing at under 6 months? That's pretty lame if you ask me. Oh well, it was only $8 to replace and the new one is lighter anyway. Anyone know where I can find a polyurethane one? Quote
mfewtrail Posted August 28, 2007 Report Posted August 28, 2007 You can modify that dogbone to use a poly bushing on one or both sides. http://www.kazmotorsports.com/tpsgarage/TGP/Engine/motor_mount.htm That "G" on the end stands for black, the same part number with a "R" on the end would be for red bushings. Most part stores can order them for you, or you can find them online somewhere. Quote
Robby1870 Posted August 28, 2007 Report Posted August 28, 2007 You can modify that dogbone to use a poly bushing on one or both sides. http://www.kazmotorsports.com/tpsgarage/TGP/Engine/motor_mount.htm That "G" on the end stands for black, the same part number with a "R" on the end would be for red bushings. Most part stores can order them for you, or you can find them online somewhere. That's what I did. If you don't want to rattle your teeth out of your head, just put the poly on the engine side of the dogbone. Quote
per0781 Posted August 29, 2007 Report Posted August 29, 2007 You can modify that dogbone to use a poly bushing on one or both sides. http://www.kazmotorsports.com/tpsgarage/TGP/Engine/motor_mount.htm That "G" on the end stands for black, the same part number with a "R" on the end would be for red bushings. Most part stores can order them for you, or you can find them online somewhere. That's what I did. If you don't want to rattle your teeth out of your head, just put the poly on the engine side of the dogbone. i did that years ago, except i went poly on boths end. mine are for sale when did robby become a woman? Quote
Guest Posted August 29, 2007 Report Posted August 29, 2007 if that went bad that fast, definetly take a look at your lower mounts... Quote
xtremerevolution Posted August 29, 2007 Author Report Posted August 29, 2007 if that went bad that fast, definetly take a look at your lower mounts... Those were replaced when the other one was replaced. I would imagine that the other engine mounts wouldn't go as bad as the engine torque mount. I launch the car pretty hard at times, so I suppose that's why the torque mount went bad. If I feel the engine stuttering off the launches, I'll take a look at the lower engine mounts. For now I need to replace my front brake caliper bushings and front bumper cover. Quote
per0781 Posted August 30, 2007 Report Posted August 30, 2007 and yes that bushing that failed is on the radiator side. Quote
Robby1870 Posted August 30, 2007 Report Posted August 30, 2007 You can modify that dogbone to use a poly bushing on one or both sides. http://www.kazmotorsports.com/tpsgarage/TGP/Engine/motor_mount.htm That "G" on the end stands for black, the same part number with a "R" on the end would be for red bushings. Most part stores can order them for you, or you can find them online somewhere. That's what I did. If you don't want to rattle your teeth out of your head, just put the poly on the engine side of the dogbone. i did that years ago, except i went poly on boths end. mine are for sale when did robby become a woman? LOLOLOLOL. I did the dual poly at first, then I got tired of it. Too much shaking for me. Quote
mfewtrail Posted August 30, 2007 Report Posted August 30, 2007 and yes that bushing that failed is on the radiator side. He said engine side, so he had the mount installed backwards. Quote
xtremerevolution Posted August 30, 2007 Author Report Posted August 30, 2007 and yes that bushing that failed is on the radiator side. He said engine side, so he had the mount installed backwards. I suppose I did. Does it really make a difference? It seemed that both bushings were identical anyway. Quote
per0781 Posted August 30, 2007 Report Posted August 30, 2007 it would only matter when you go to tilt the motor forward Quote
xtremerevolution Posted August 30, 2007 Author Report Posted August 30, 2007 well I've got those poly bushings coming in some time this or next week. I'll let you guys know how it feels once they're installed. Quote
