3.1 problem VERT DOWN. engine carnage.. Compression checked!
BACK IN... WHITE!!!!!! (the car is white)
I replaced both the valve springs on number 4, and while they were out, I spun the valves so they would rub the seat. compared to a couple used valve springs I had laying around, these had lost a little or their tensile strength, and were about 1mm shorter.
I only redid the compression test for 2, 4, and 6
Here's what I got:
2 165
4 165
6 182
SWEET!!!!!!!!! only 1 is lower than 165!!!!!!!!!!!!!!!!!!!!!!!!!!!
SHE IS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and a final update.
One hell of a first return to service drive... Michigan and back... with no problems!!!!! SWEET!!!!
perhaps I should rename her....
She is no longer to be known as busted.. she is now known as... (a little help here please, anyone???)
i gotta hand it to you ken you are one of the few people i know that uses nylon string, and a drill to do a valve job. most certinally one of the smoother running 3.1s i've seen in awhile!
