Removing radio from 90 GP
How the hell do I remove the radio from my 90 GP? I've read the install faq, but it didn't help much. Need help!
open up the glove box, there are 2 i belive 7mm bolts there... also under the stearing wheel, there is a panel you have to take off then you can get to the other 2 bolts on the other side. everything should be 7mm to get the housing off, then I believe they are 10 mil that holds the radio in place.
by the way, to make it easier when you open the glove box, you can take the little arms out of the box to lower the door all the way just by kinda pushin them to the side a little... you will figure it out, it's quite easy to do.
