shyguy164 Posted August 23, 2007 Report Posted August 23, 2007 So my convertible died on the freeway yesterday and I haven't been able to get it restarted (VIN X). Checked all fuses and relays. Fuel pump runs and is pressurizing the rails. Pulled spark plug wires and watched them spark to the block when I crank the starter. Any ideas? How does one know when the timing belt goes? Any symptoms? Thanks! Quote
ManicMechanic Posted August 23, 2007 Report Posted August 23, 2007 Usually when it goes, it does just that...Pull the front belt cover (2 8mm bolts, IIRC) and check... Quote
shyguy164 Posted August 23, 2007 Author Report Posted August 23, 2007 Yeah, it's the timing belt. Anyone want to do it for me? I'd obviously pay you. Quote
slick Posted August 23, 2007 Report Posted August 23, 2007 Your a bit far for most of us, but there are a few members out that direction that know a thing or two. Quote
ManicMechanic Posted August 23, 2007 Report Posted August 23, 2007 If I were single, I'd do it...My sister lives up there, give me a reason to go visit her...Alas, my wife needs me here. Quote
Crazy K Posted August 24, 2007 Report Posted August 24, 2007 A song by Queen comes to mind NOOOO!!!!!!!!!!! it is not impossible to fix... but PITA. hope you get it done! Quote
GOT2B GM Posted August 24, 2007 Report Posted August 24, 2007 Its not THAT bad. You should buy a service manual and give it a try. You might surprise yourself. Just give yourself a full day. Quote
Crazy K Posted August 24, 2007 Report Posted August 24, 2007 GOOD TIP. once you do all that and have a new belt on. manually turn the engie at the crank, to make sure parts don't intersect! the job is doable but will take some time. Quote
GutlassSupreme Posted August 24, 2007 Report Posted August 24, 2007 EXACT SAME shit happened to me and my baby. thought it was a huge problem. i even checked the belots on the highway but obviously was blind. so now im gonna pay like 1000 to replace it. but i will admit, i miss her to death, she's so cozey inside. Quote
IRONDOG442 Posted August 25, 2007 Report Posted August 25, 2007 I miss my 3.4X convertible like I miss that last case of blistering anal warts I just got over. Quote
rockfangd Posted August 25, 2007 Report Posted August 25, 2007 usually the first clue to a broken timing belt is hearing the engine turn over faster than normal for no appearant reason, just picture taking off the serpentine belt and the engine would crank really fast lol, best of luck, FIX IT Quote
theghoul Posted August 25, 2007 Report Posted August 25, 2007 PITA, $$$ but fixable Welcome to the club Quote
White93z34 Posted August 25, 2007 Report Posted August 25, 2007 if i was closer i'd do it. not that terrible of a job, but for your first time give yourself a full weekend. Quote
