hell_raiser Posted August 20, 2007 Report Posted August 20, 2007 im thinking of doing this swap whats easer its a 95 cutless 4 door 3.4 dohc has more hp but a 3400 has the same tork give me some ideas thanks Quote
digitaloutsider Posted August 20, 2007 Report Posted August 20, 2007 tork FWIW, You should be able to run a 3400 on a 3100 harness/PCM. Quote
slick Posted August 20, 2007 Report Posted August 20, 2007 Yes, you can run the 3400 on your 3100 stuff. You will need to change over a few things, but otherwise, it will work. Actually, you should be able to run the 3.4 on the 3100 stuff as well. You will have to re-route your harness a bit, and change over a few other things as well. Quote
Psych0matt Posted August 20, 2007 Report Posted August 20, 2007 if you're going for easiest, 3400 would be a lot easier. i guess it also depends on which is easier to get a hold of in the first place Quote
jeremy Posted August 20, 2007 Report Posted August 20, 2007 like mentioned already the 3400 will be slightly easier, that being said ...the 3.4 DOHC will be more fun to drive Quote
Psych0matt Posted August 20, 2007 Report Posted August 20, 2007 the 3.4 DOHC will be more fun to drive QFT! Quote
CSI_MuNkY Posted August 20, 2007 Report Posted August 20, 2007 the 3.4 DOHC will be more fun to drive QFT! But much more difficult to modify Jamie Quote
chadz34 Posted August 20, 2007 Report Posted August 20, 2007 the 3.4 DOHC will be more fun to drive QFT! But much more difficult to modify Jamie It's like any other engine, give it what it needs to perform and it will.......money is always an issue with that engine. Quote
hell_raiser Posted August 24, 2007 Author Report Posted August 24, 2007 well i can get a 2 door cutty for 200 bucks with a 3.4 dohc Quote
Brian P Posted August 24, 2007 Report Posted August 24, 2007 like mentioned already the 3400 will be slightly easier, that being said ...the 3.4 DOHC will be more fun to drive Not in its stock form it won't. You're talking about a ~15-20 hp difference. The bigger dilemma would be the need to swap harnesses and PCM's from another '95 DOHC equipped W-body. If you're gonna run the DOHC on the 3100 PCM it'll drive like ass, and at the very least, starve for fuel. The 3400 is easier to run on a 3100 computer. Again it'll not be running to its potential but it's not going to be as far off as the DOHC. In fact, if you install '96-99 3400 injectors, the tune should be pretty close. So it looks more like this: For the DOHC: Swap the motor, mounts, exhaust downpipe, PCM and harness, should also swap the tranny since the overall ratio is slightly different (3.43 vs 3.33) For the 3400: Swap the motor, couple brackets, use early 3400 injectors, run it. Quote
hell_raiser Posted August 25, 2007 Author Report Posted August 25, 2007 3400 it is lol. will a top end swap do the same as a 3400 swap? engine just started to hesitate(spelling) and knock a bit 186,000 km Quote
Brian P Posted August 25, 2007 Report Posted August 25, 2007 a top end swap will be an improvement, but won't be as strong as the 3400. What kind of knocking do you hear? When the engine is cold? warm? Quote
hell_raiser Posted August 25, 2007 Author Report Posted August 25, 2007 warm it dose it at low rpm some times and at 4000 Quote
Brian P Posted August 25, 2007 Report Posted August 25, 2007 Warm knocking could be a bad sign. You may get lucky and it just is coming from a bad lifter, but worst case scenario it's coming from a worn or spun bearing. Got any audio of it? Quote
hell_raiser Posted August 26, 2007 Author Report Posted August 26, 2007 well i could try to get some audio. its weird if i baby it shes fine no knock but if i give her passing some one she knocks at 5 rpm and hard acceleration it knocks too, off the line at that. Quote
