Spoon Posted August 18, 2007 Report Posted August 18, 2007 I swapped out my 2.8l for a 3.1l the idle is fine but the engine stalls as soon as the gas is pushed. used wiring,egr,ecm and throttle body from 2.8l, any ideas. Quote
19Cutlass94 Posted August 18, 2007 Report Posted August 18, 2007 hows the fuel pressure? fuel filter? Quote
Spoon Posted August 18, 2007 Author Report Posted August 18, 2007 fuel pressures good,so i asume fuel filters ok Quote
Addicted To Boost Posted August 18, 2007 Report Posted August 18, 2007 What kind of shape are your fuel injectors in? Quote
meltboy1 Posted August 18, 2007 Report Posted August 18, 2007 injectors or MAP, you gettin any engine codes? Quote
Spoon Posted August 18, 2007 Author Report Posted August 18, 2007 I drove the donor car around for a few days before I removed the engine, ran good. no codes are showing up. Quote
BXX Posted August 18, 2007 Report Posted August 18, 2007 You are still using the 2.8L EGR, right?? Also, the 3.1L has different ECM programming than a 2.8L.... Think of it this way, the 3.1L is gonna want a bit more fuel. Check and see if you have any codes currently... Quote
Spoon Posted August 19, 2007 Author Report Posted August 19, 2007 Got it figured out. Map sensor was buggered up. installed known good one now car runs good. Thanks meltboy1 Quote
