acq Posted August 13, 2007 Report Share Posted August 13, 2007 so the driver side door handle broke..ok common problem so ill go fix it call up the local napa and they want almost $300 for the handle cuz it was different from all the other w bodies and i was like f*ck that and i went to the junk yard and they said they didnt have any and that the door handle for the regal was different so i went and found one off a 93 gtp he said it wouldnt work but for $35 i took it and it looked partically new sure enoph the thing bolted right in place with out a problem and it opend and closed fine but when i locked the door when i went back to get it the door wount unlock from the inside or out side i can hear the locks working but it wont unlock any ideas? Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted August 13, 2007 Report Share Posted August 13, 2007 Check the linkage. You're going to have to take the door apart to make sure it is properly adjusted. If you adjust one rod (or more if necessary), the door should open again. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted August 13, 2007 Report Share Posted August 13, 2007 Yeah just sounds like the linkage slipped or came out of adjustment...I believe it is possible to get the door panel apart enough with the door closed to be able to see what is going on inside. Quote Link to comment Share on other sites More sharing options...
acq Posted August 13, 2007 Author Report Share Posted August 13, 2007 ok thanks i assume u mean the linkage to the out side handle right Quote Link to comment Share on other sites More sharing options...
1990lumina Posted August 13, 2007 Report Share Posted August 13, 2007 I'm talking about the linkage inside the door - since you said it was working before you locked it. Sounds like there is something wrong with the locking part of the linkage. Quote Link to comment Share on other sites More sharing options...
acq Posted August 13, 2007 Author Report Share Posted August 13, 2007 all the linkage on the instide of the door appears to be connected right Quote Link to comment Share on other sites More sharing options...
acq Posted August 13, 2007 Author Report Share Posted August 13, 2007 i just got my door open not 100% sure how but now that its open i can tear it apart to figure out what the hell the problem is Quote Link to comment Share on other sites More sharing options...
acq Posted August 13, 2007 Author Report Share Posted August 13, 2007 its definitly a lock/door latch problem Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted August 13, 2007 Report Share Posted August 13, 2007 It may look ok, but you may have to tinker with it to get it exactly right. My linkages were very finicky. Good luck. Quote Link to comment Share on other sites More sharing options...
acq Posted August 13, 2007 Author Report Share Posted August 13, 2007 ok u guys were right it was just rele far out of adjustment that it wasnt allowing the door to open from inside or out thanks for ur help Quote Link to comment Share on other sites More sharing options...
pwmin Posted August 14, 2007 Report Share Posted August 14, 2007 good news! Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted August 14, 2007 Report Share Posted August 14, 2007 Glad it's fixed! Quote Link to comment Share on other sites More sharing options...
rockfangd Posted August 14, 2007 Report Share Posted August 14, 2007 . and the differences in the coupe handles is the length of the handle to the top of the door, otherwise the latches are exactly the same. Quote Link to comment Share on other sites More sharing options...
