Stevo Posted August 5, 2007 Report Share Posted August 5, 2007 I want to hack as many parts from the 94' as possible so what I need off the top is the exaust from the downpipe back to the mufflers. The exaust is dual on the 94' unfortunately and the 88' is single. Then I need the gas tank and I am unsure if I can use the sending unit or not. Is it possible? Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 5, 2007 Report Share Posted August 5, 2007 sendin g unit id different. BUT... you can use it if you change it with all the associated hoses and lines, but the lone lines that run to the front if requiring a change... would need you to drop the frame. Quote Link to comment Share on other sites More sharing options...
