cramez Posted August 2, 2007 Report Posted August 2, 2007 Car is a 99 Grand Prix GT, 3800 auto, 100k on it. The car started shaking and shifting odd the other day and after a couple minutes triggered the ses light. The only code that was on it was "Torque converter solenoid stuck on" I'm used to my older 3-speed 3T40, and this is the newer 4-speed 4T65 if I remember right. Does the TCC fail in these like it's known to in the 3-speeds? Is it a pretty similar job to change? Quote
Andrew Posted August 2, 2007 Report Posted August 2, 2007 with only 100k that seems a little early, but its not unheard of. replacing the part should be a similar process. Quote
digitaloutsider Posted August 2, 2007 Report Posted August 2, 2007 As of now, I've lost two 4T65E's due to the exact same reason. Both under 100,000 miles. Try to get it swapped out as soon as possible. You might be able to save the tranny. Quote
cramez Posted August 2, 2007 Author Report Posted August 2, 2007 So the problem is definitely the TCC? This must operate slightly different than the one in the old 3-speeds, I drove that car in 2 rather than drive for almost six months and it never hurt anything, and that was almost 100k ago. This is the part I need then, correct? http://www.napaautoparts.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=TCS530&Description=Transmission+Control+Solenoid Quote
Andrew Posted August 2, 2007 Report Posted August 2, 2007 http://www.intense-racing.com/ has them for $30 each. Quote
cryptnix Posted August 3, 2007 Report Posted August 3, 2007 and about a $300 job at any of the local shops in your area ... at least thats what i cost my lazy ass to get repaird Quote
cramez Posted August 3, 2007 Author Report Posted August 3, 2007 So it's basically the same job as the 3-speed, just pull the side pan off the trans and just change it out? Sounds like it shouldn't be too bad, hopefully. This car's getting expensive kinda quick, and it's only at 100k. Quote
cryptnix Posted August 3, 2007 Report Posted August 3, 2007 So it's basically the same job as the 3-speed, just pull the side pan off the trans and just change it out? Sounds like it shouldn't be too bad, hopefully. This car's getting expensive kinda quick, and it's only at 100k. tis about the time shit breaks on all the cars i've owned lol ... but yep its as easy as that Quote
cramez Posted August 4, 2007 Author Report Posted August 4, 2007 OK, this is getting annoying. I talked to my parts guy who used to work at a GM dealership and he claims that if it's not dying at stop signs it's probably not the TCC, it's probably the valve body sticking. Any suggestions on what I can do besides change the filter & fluid and see how long it lives? I definitely don't have the time to change the tranny right now if I can help it. Quote
cryptnix Posted August 4, 2007 Report Posted August 4, 2007 OK, this is getting annoying. I talked to my parts guy who used to work at a GM dealership and he claims that if it's not dying at stop signs it's probably not the TCC, it's probably the valve body sticking. Any suggestions on what I can do besides change the filter & fluid and see how long it lives? I definitely don't have the time to change the tranny right now if I can help it. the symptoms (shaking car ... shifting odd etc. etc.) sounds like its throwing itself into maximum adapt question is why ... i believe the IAC sensor can cause something such as this however whomever can correct me then sweettt... but i cannot diagnose your car over the internet you need to get it scanned. $70 sounds like a lot (at least around here thats the going rate) but its also for an investment of which you've made... Quote
