timestalker45 Posted July 31, 2007 Report Posted July 31, 2007 im coming to a conclusion that i have a bad ground. my dash board and running has been rough a little, such as if i turn on my turn signal my rpms go up and down. so can anyone give me some good starting points to check for this bad ground such as common areas? Quote
PCGUY112887 Posted July 31, 2007 Report Posted July 31, 2007 What car? On mine most everything grounds to 2 transmission bell housing bolts. Quote
GP1138 Posted July 31, 2007 Report Posted July 31, 2007 Volts jumping up and down with the turn signal could also be a sign of a bad alternator. Quote
timestalker45 Posted July 31, 2007 Author Report Posted July 31, 2007 it is a 92 cutlass supreme s my volt meter has been fine reading acrite voltage, plus i did test the altinator. as i said the rmp goe up and down when the turnsignal is on, my speedometer drops to 0 when stopping without being stoped, my temp gauge will go up and down even though i replaced the sensor, and finally but not least after removing the negative wire a while back the e-brake light remians on all the time(i disconected the e-brake, and replaced sensor) i also found out betweeen the ground wire and the power wire to the sensor i have continuity when i shouldnt. so i ahve come to the simple and hopefully right conclusion that it is a bad ground, unless some one has a better conclusion note: i changed radio for a custom cd-player while doing so i had to wire a wire to the fuse box do to my memorie wire only suplying .2mv, my radio needed 12.(i thought all radios run off 12v i might be wrong but that struck me as odd) note2: i thought it was my cluster, but that couldnt cause all the problems, well i dont think so Quote
Andrew Posted July 31, 2007 Report Posted July 31, 2007 follow all the cables off your negative battery terminal. make sure the cable ends and mating surfaces are clean and without corrosion. Quote
timestalker45 Posted July 31, 2007 Author Report Posted July 31, 2007 how many cables actualy come off the battery? Quote
ns87 Posted July 31, 2007 Report Posted July 31, 2007 When I cleaned up two grounds (one on each corner of the engine bay behind the headlights) that helped your problem a lot! Quote
Andrew Posted July 31, 2007 Report Posted July 31, 2007 how many cables actualy come off the battery? stop being lazy and just go look, jeesh. Quote
19Cutlass94 Posted July 31, 2007 Report Posted July 31, 2007 how many cables actualy come off the battery? stop being lazy and just go look, jeesh. 80 bagiallion wires! Quote
timestalker45 Posted July 31, 2007 Author Report Posted July 31, 2007 fine ill look where that guys said to, and i hate fixing cars, Quote
19Cutlass94 Posted July 31, 2007 Report Posted July 31, 2007 then bring it to a shop and stop asking these fucking questions to which you dont listen Quote
timestalker45 Posted August 1, 2007 Author Report Posted August 1, 2007 well i have done that but there lost too? i mean they have tried to find the problem but keep coming up short and it cost to much money to keep guessing so thats why i ask for help Quote
SigEpCutlass Posted August 1, 2007 Report Posted August 1, 2007 Here's a shot in the dark. The Auxiliary post is connected to the battery cables, and it has it's own ground (can't remember what to at the moment). The Aux post has a tendency to go bad or get corroded. I'd check the post, and most especially it's ground. That may be your bad ground. It's easy to check, and shouldn't cost much to replace it if necessary. Btw, are you sure your battery cables aren't corroded? Quote
timestalker45 Posted August 1, 2007 Author Report Posted August 1, 2007 those were replaced when the egine was swapped about 8 months ago. ok ill check that, when i get some time and let every one know. used the scannel tool yesterday and my speedometer is correct, even though it dropw on ocasion while stopping Quote
