just a wiper recommendation for everyone
Wanted to post that although the 95 Cutlass specifies 20" wipers, 21" ended up fitting easily and it's nice to see just a little bit more in the rain. 22"s may have even fit??
I suggest running your wipers while watching their path from outside the car if you're thinking about this "upgrade". I went with Bosch MicroEdge.
Brian
I tried aftermarket wipers (21's) then took them back. I didn't like how tall they were. I prefer the stock flat low look so I'm stuck with 20's. Thinking about getting a second set from a yard though. I had to tighten up some of the flex/link areas awhile back.
Ive got 22's and theyre great, my friend had used 24's without a problem
the way my wipers are timed...
hehe, how bout you make a write up on how to re time the wipers :D
What exactly do you mean by the flat low look? Do they not tuck under the cowl if they're too long, or is that not what you meant?
