super_fro_daddy Posted July 25, 2007 Report Posted July 25, 2007 Well, I broke a wheel stud. I searched on here and it said I could just pound it out and pund a new one in. Do I just use a little sledgehammer and give it a few good hits?? It sounds too easy to me but I am no expert. Thanks. Quote
slick Posted July 25, 2007 Report Posted July 25, 2007 Your gonna have to pull the hub off to get the stud in and out. Quote
super_fro_daddy Posted July 25, 2007 Author Report Posted July 25, 2007 well, I got the stud off. Is getting the hub off something I should have a shop do?? Its a rear stud by the way Thanks Quote
Nick1234 Posted July 25, 2007 Report Posted July 25, 2007 never had to do a back stud. But if you have clearance to pound the new one in, then that is all that is requires. if you don't, then just remove the 4 bolts that hold the hub assembly in. Gotta remove the caliper, rotor and bracket. also disconnect the abs sensor if you have one. Quote
White93z34 Posted July 25, 2007 Report Posted July 25, 2007 a rear stud i believe just slides right in, no hub removal required. Quote
Donutboy97 Posted July 25, 2007 Report Posted July 25, 2007 also, if you can't pound it, but if you can get some threads through, take the lugnut and put that on the bolt to force it through. Quote
super_fro_daddy Posted July 25, 2007 Author Report Posted July 25, 2007 also, if you can't pound it, but if you can get some threads through, take the lugnut and put that on the bolt to force it through. I was thinking the same thing. Another question I had about putting it on was you just put it on and when you put the lugs on it just locks the stud on. Correct?? Thanks Quote
Andrew Posted July 27, 2007 Report Posted July 27, 2007 yeah just use a lug nut to tighten up the new stud. it will take quite a bit of force. Quote
super_fro_daddy Posted July 28, 2007 Author Report Posted July 28, 2007 it will take quite a bit of force. I tightened 'er down pretty hard but there is still a tiny bit not pulled thru. I'm ready to get out the cheather bar, but am scared I will break it again. Quote
slick Posted July 30, 2007 Report Posted July 30, 2007 a rear stud i believe just slides right in, no hub removal required. It may actually, now that I think about it. For sure on the hub removal for the fronts though. Quote
1990lumina Posted July 31, 2007 Report Posted July 31, 2007 When I broke the wheel stud off my Lumina I cut the stud in half with a hack saw so I could push it through the back without removing the hub - and I went to the GM parts desk and bought a shorter stud that went in without hub removal, and still did the job. I don't have aftermarket wheels so I really don't care how long the stud was as long as it got some of the lug nut - it was a part listed for my car so obviously meant for what I used it for! Quote
EFFENDI Posted September 7, 2007 Report Posted September 7, 2007 yeah i took some studs into my gm dealer.... and asked if they had shorter ones..... they gave me OEM studs... they were like a quarter inch shorter than any i had bought at parts stores... which was perfect to get in without hub removal....... Quote
