92blackz34 Posted July 25, 2007 Report Posted July 25, 2007 how hard is a back brake job if you get the special tool. is anything else that needs to be done special back there its a 92 z34 Quote
DOHCRagtopguy Posted July 25, 2007 Report Posted July 25, 2007 Do yourself a favor and buy 2 loaded rear calipers (calipers w/pads attached). Turning back that piston can be a royal bitch on these cars with or without the tool. Sometimes the piston must be pushed in and turned at the same time in order to retract fully. I've had enough bullshit with that, so now I buy loaded calipers for the rear on my W-body. Quote
xtremerevolution Posted July 25, 2007 Report Posted July 25, 2007 I've always used a c-clamp. Worked every time, and brakes just fine afterward. I've changed the rear brakes 4 times now since I bought the car. Quote
GP1138 Posted July 30, 2007 Report Posted July 30, 2007 I used this really cool tool at work when I last did rear brakes. It consists of two metal shims, with a threaded insert that turns the piston while keeping pressure on the two shims, that go between the caliper and the piston. The threaded part has a 1/2" head at the end you turn with a wrench. Easiest rear pad job I've ever done. I think it was special ordered though, but I'd ask about it at AutoZone or Advance. Quote
jeremy Posted July 30, 2007 Report Posted July 30, 2007 the rear brakes are pretty easy, but I've always used a special tool like John mentioned Quote
badassoldspower Posted July 30, 2007 Report Posted July 30, 2007 I've always used a c-clamp. Worked every time, and brakes just fine afterward. I've changed the rear brakes 4 times now since I bought the car. That doesnt work on the rear calipers, being as they are an integral parking brake style caliper, there is a threaded shaft behind the piston, you cannot simplly push them back, people have tried using a vise to compress them that way, which ruins them. Quote
GutlessSupreme Posted July 30, 2007 Report Posted July 30, 2007 stick a small block of wood between the piston and the c-clamp. the block will squish to fit the slots on the piston and will twist it. Quote
intern8tion9l Posted July 31, 2007 Report Posted July 31, 2007 i've always used a pair of channel locks and never had an issue Quote
GnatGoSplat Posted July 31, 2007 Report Posted July 31, 2007 I got this on sale from Harbor Freight when it was $10. It can rotate while pushing in at the same time. Well worth it when it goes on sale. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40732 Quote
GP1138 Posted July 31, 2007 Report Posted July 31, 2007 I got this on sale from Harbor Freight when it was $10. It can rotate while pushing in at the same time. Well worth it when it goes on sale. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40732 Exactly what I used at work. Turns the job into a no-brainer. Quote
19Cutlass94 Posted July 31, 2007 Report Posted July 31, 2007 Ive never used the GM tool for that. clamp and a screwdriver always worked for me Quote
