engine temp prob??
alright so i have the LQ1 engine i just had the water pump replaced and my engine still seems to be getting hot but not overheating?
i have the UB3 cluster in my car i dunno if this is where the guage should be sitting at normal operating temp or if it is getting hot?
anyone with a UB3 is this where the temp should be sitting or is my engine running hot?
[attachment deleted by admin] Removed to free up storage space.
Did you change the thermostat and bleed the cooling system?
i havent changed the T-stat but i did have the system bleed when they replaced the water pump
how's your radiator cap? do you have a lot of debris caught in your radiator? are your fans turning on?
I'm thinking along the same line as Paul. If the temp gauge is that high, the fans should be running. If you need more help with fans, try a search on the techniques people have used to diagnose those issues. Is the hose running from the radiator to the vicinity of the t-stat hot to the touch? If it is, the T-stat is open like it should be at that temp.
i just replaced the cap cuz thats what i thought the prob was but it wasnt so its a new cap an im not sure i havent checked that hose and as for the fans i can hear them running when the cars turned on but soon as i shut her down they turn off as well
My UB3 reads 7 bars when the engine is fully warm.
Is your upper radiator hose red hot and the lower one cold?
i dunno ? i havent checked wheres the lower one?
On the opposite side of the radiator at the bottom.
if your coolant system check outs okay, then check your oil. can you smell coolant when the car is running?
no i dont smell coolant when its runnign and i just changed the oil to synthetic and i gave it a engine flush and it seems to be runnign a little bit cooler but not much
